Problems using the default port tcp/2049/nfs
mamud810729
Good Afternoon,
I have the following problem: when you need to configure a rule or access-list to port tcp / nfs I presented the following problem. (ATTACHMENT).
I have a FWSM 3.2 (3)
As I can solve the problem?
I appreciate a prompt solution.
Oscar.
jfiranzi
Hi Oscar,
I'm afraid you found the Physical Security forums (video surveillance, physical access control etc.)  The forum you want to post this question to is the Firewall forum as they should be discussing FWSM there.
I hope that helps,
Jim
