Problems with connectivity between LAN on VPN Site to Site (ASA-router)
I configured a VPN Site to Site with an ASA 5570 ( Headquarter) and a router 881 ( Branch office) , LAN networks are 192.165.0.x and 10.213.21.x , the problem is that I don't have connectivity between these LAN networks only between peers however tunnel is established, when I checked logs in ASA appears build and after teardown but never appears when ACL match with request of ping between LAN networks, in the VPN sessions only appears Tx bytes not Rx bytes and I configured static routes and ACLs for interesting traffic and permit incoming  and outgoing traffic so I don't know which can be error.
Thanks for your help
Ana Maria
Roman Rodichev
Level 7
Level 7
did you do nat 0 for those networks? you need to make sure traffic is not nat'ed. Post your config.
I attached router configuration but I don't have ASA configuration however in ASA is configured ACLs for outgoing and incoming traffic, a tunnel group, group policy, ipsec rules and static routes, if you need I can send a topology to please collaborate me.
Ana Maria Fuentes
