Question on viewing dropped packets and Telnet issue
Mark Mattix
Level 2
Level 2
Hello, I have a "noobish" question about an ASA. A remote site is trying to establish a Telnet session with a private network but our ASA allowing the remote site to come in seems to be blocking the connection. I was wondering on what's the best method to capture packets or to view the status of packets being allowed or rejected by our ASA?
Would the command, "show logging asdm" display all packet information that's being allowed and also dropped on the Inside, Outside and DMZ interfaces? I'm trying to figure out the easiest command to view the traffic being allowed and also denied. Thanks!
3 Accepted Solutions
The easiest way is to enable logging to a remote syslog-server where you can see the denied packets and also the allowed connections. If you don't have a syslog-server you can log to the local buffer:
logging buffered informational       ! <--- for logging to RAM
logging host inside a.b.c.d          ! <--- your syslog-server
logging trap informational           ! <--- which level to log to syslog
logging on
show logging                         ! <--- shows the local log-buffer
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
please provide a diagram of your setup to see how the traffic flows.
It's denied by the implicit "deny ip any any". But to know why you need to provide more info. The config and also your setup which addresses connect from where to which addresses.
9 Replies 9
logging on
Thank you Karsten!
Mark Mattix
Level 2
Level 2
Well I have set up logging for the ASA but do not see any messages about it dropping a telnet or port 23 packet from my remote site. I also check the log of the router at the remote site and see no notifications about there being an issue.
The remote site connects over an IPSec tunnel, anyone on this site cannot access the telnet application. If you're on our main site it works fine. Pings from the remote site to anywhere on our main site work fine. I'm not sure what's going on and I have ran out of ideas on how to troubleshoot this, any help would be really appreciated!
by default, all traffic leaving the IPSec-tunnel is allowed. So it's more likely that the problem is somewhere else. But you can use the command "packet-tracer" to simulate the problematic traffic.
Hmm, if the traffic is allowed through the IPSec tunnel then the other end of the tunnel should be the only area, right? The ISP has no idea what's traveling over the tunnel so there shouldn't be an issue with that port on the Internet, right? I'll try out that packet-tracer command tomorrow, thanks!
Mark Mattix
Level 2
Level 2
Karsten, could you help me understand the output of the packet-tracer command?
After issuing the command there are 4 phases and then a result. The first 3 phases Allow the packet to pass through but the 4th phase denies it.
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xcd123eb1, priority=11, domain=permit, deny=true
        hits=10857448, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
I assume these phases relate to the ACL but how do I know what portions of the ACL? Also, I'm not sure if it makes a difference but I changed some numbers in this output because I'm not sure what the values represent. Thanks for the help!
Mark Mattix
Level 2
Level 2
I finally got the issue figured out! The problem was at the remote site. In the VPN's ACL the traffic for the telnet session was not specified. I originally thought this was the issue and made the change but it didn't work. I didn't realize that the config had to be saved then the VPN tunnel rebuilt for the change to take effect. I guess the reason why the firewall said it was being denied was because the ACLs were not setup for the network but the VPN connection was still able to tunnel it through, bypassing the outside ACL.
Thanks for the help Karsten!
