range of public IP on outside interface
adriatikb
Can i use a range of IP on outside interface of pix firewall, and inside host to use one of them randomly? to use PAT on this range?
thank you
zulqurnain
Level 3
Level 3
hello,
yes that is possible.
global (outside) 1 172.16.1.1-172.16.1.20
all inside host will use one of the above defined range ip addresses randomly as they will access outside.
HTH, please rate it
thank you ,
can i use these for pix firewall v6.3 ?
Yes, this works on both V6 and V7 software.
It doesn't allow for over subscription on the pool so isn't really PAT but more NAT. But that is just splitting hairs.
