Simple NAT of inside interface from outside
global-gossip
Just when I think I've got my head around nat, global and static commands i find myself struggling to get this 'simple' config working...
I have a pretty default config:
interface Vlan1
nameif inside
security-level 100
ip address 10.20.30.50 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.20.30.0 10.20.30.0 netmask 255.255.255.0
I can ping from inside host to outside host and vice versa.
All i want to change is to NAT all traffic coming from the outside network on the inside interface so if i start to ping a host on the inside network from the outside, the traffic appears to come from 10.20.30.50 (my inside interface IP).
I'd appreciate any help.
Julio Carvajal
Hello Eshan,
You will need to do
global (inside) 1 interface
nat (outside) 1 0 0 outside
Do no forget the outside keyword at the end.
Also you will need to allow the traffic via an ACL on the outside interface
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Hello Eshan,
You will need to do
Julio
Julio Carvajal
