ā01-08-2013 10:48 AM - edited ā03-11-2019 05:44 PM
Hi Friends,
Let me explain about my setup with a block diagram.
Having a Firewall with two different Service Provider internet Link. Having a default route for the ISP 1 and static route for the ISP 2 depends on the requirement.
Now we are building a Site to Site tunnel between our ASA and customer Router and we are planning to build that via ISP 2 Link. And also we don't want any NAT between the LAN IP Address. ( ie My LAN is 10.10.10.0/24 and Customer is 192.168.10.0/24)
We had a static route in our Firewall for the Customer Peer IP Address and created Interested Traffic list also. As we don't have NAT control enabled we thought no need to configure (nat 0 access-list XXX).
Now the tunnel is showing up from My End and also from Customer end but ..in my ASA i am able to see only decaps numbers and encaps is Zero. More Over i am not able to send any traffic to customer LAN.
Where is the exact issue and still what are the configuration i need to modify to make it as Successful.
GanAlagu
ā01-08-2013 03:09 PM
Hi Gan,
Try adding this route to the configs on the ASA like this
route nameifISP2 192.168.10.0 255.255.255.0 ISP2
Please rate this post if helpful.
Shamal
ā01-08-2013 04:59 PM
Hello Ganesan,
Please share the configuration you have please, ( Entire one) Use random ip addresses for the VPN peer and your Ip addresses so we can understand and provide you an accurate solution while being secure
Julio
