Source Fire Connection Events not showing/recording
jseidl
Under the Connections>Events we do not get any data
18 Replies 18
Pujita Patni
Do you haev logging enabled on your Access Control Policy ?
Pujita
Yes logging is on. The Event were working. They stop about 10 days ago
I have same problem, anything perhaps OK but cannot show traffic. if I using firewall transparent Firesight can show traffic but still one error when I check command:
show service-policy sfr
Service-policy: global_policy
Class-map: sfr
SFR: card status Up, mode fail-open monitor-only
packet input 0, packet output 0, drop 0, reset-drop
If I change to router mode anything perhaps OK but no traffic show, no record show and still error above
Class-map: sfr
Please Help me!
Hi ,
Have you created an access-list to redirect the traffic from ASA to SFR , check the hitcounts on the access-list , if we dont see any hitcounts on access-list then in that case the ASA itself is not pushing any traffic to SFR , I am assuming the basic connectivity have already been checked and the management interface on ASA is up and running ?
Aastha Bhardwaj
Rate if that helps!!!
The problem was a corrupted database file. Working with TAC the issues was resolved. Thx All.
Hi jseidl
can You tell Me the corrupted database file name? it can be asasfr-5500x-boot-5.3.1-152.img or asasfr-sys-5.3.1-155.pkg or firesight management on esxi. I will download it again.
I cannot open TAC because i haven't contract number.
thank you!
Hi ,
If you are planning to reimage the SFR on ASA , first you would need the .img file.
Detailed procedure : http://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html
Aastha Bhardwaj
I'm having the same issue (nothing being logged to event dashboards) with a new installation, everything is configured correctly as I can tell. Logging enabled, redirect in place and showing packets.
I have one installation that is working perfectly, and a second one, the problem one with "no data".
What did the TAC do to fix your issue with database or other solution. I have a TAC case open but this was just deployed to production and need to fix asap, and TAC ask some questions then disappeared on me.
Hi jwornstaff
You must sure traffic throught from inside to outside (nat, access list permit from inside to outside). After put a laptop test ping or access internet from inside. traffic will show in dashboards. :)
thanks
Hi Aastha Bhardwaj
I was config the config:
ciscoasa(config)# access-list sfr_redirect extended permit ip any any
ciscoasa(config)# class-map sfr
ciscoasa(config-cmap)# match access-list sfr_redirect
ciscoasa(config)# policy-map global_policy
ciscoasa(config-pmap)# class sfr
ciscoasa(config-pmap-c)# sfr fail-open
ciscoasa(config-pmap-c)# sfr fail-open monitor-only
ciscoasa(config)# service-policy global_policy global
but no thing can show, can You send to Me the file show running config of your firewall asa.
Thank you!
Aastha Bhardwaj
Hi, Go on Access control policy and check if Logging is enabled on it and then also on right hand corner you have the window to increase the time frame , increase that for a week and see if you get any events out there.
If all of that is fine check on the sensor:
/var/sf/detection-engine , press tab and then go to instance
/var/sf/detection-engine/*/instance-1 ,Check for conn-unified bookmark file , see what date it was updated.
Also check the below on Defense Center and Sensor:
pmtool status |grep SFData
SFdatacorrelator service should be running.
Aastha Bhardwaj
Thx. I will try to complete your above idea. I am new to this product.
I do have this in the syslog:
Nov 19 2015 13:41:38 Sourcefire3D SF-IMS[31120]: [31240] SFDataCorrelator:MySQLEvent [ERROR] mysql_stmt_prepare failed: 1017: Can't find file: 'rna_flow_stats_1440774000' (errno: 2); cmd: INSERT INTO rna_flow_stats_1440774000 (sensor_id,protocol,initiator_port,responder_port,first_packet,last_packet,packets_sent,packets_recv,bytes_sent,bytes_recv,client_app_version,info,netbios_domain,flow_type,tcp_flags,security_zone_ingress_id,security_zone_egress_id,interface_ingress_id,interface_egress_id,user_id,initiator_ip,responder_ip,src_device_ip,fw_policy_id,fw_rule_id,fw_rule_action,fw_rule_reason,app_proto_id,client_app_id,web_app_id,url_category,url_reputation,fw_monitor_rule_id_1,fw_monitor_rule_id_2,fw_monitor_rule_id_3,fw_monitor_rule_id_4,fw_monitor_rule_id_5,fw_monitor_rule_id_6,fw_monitor_rule_id_7,fw_monitor_rule_id_8,ip_rep_src_dst,ip_rep_layer,ip_rep_category,instance_id,counter,file_count,ips_event_count,initiator_country,responder_country,ioc_count,nf_src_as,nf_dst_as,nf_snmp_in,nf_snmp_out,nf_src_tos,nf_dst_to
The above repeats every minute.
I believe that SFdatacorrelator is running see attached
YOu would need to login on the Defense Center via the Cli.
+Ssh to the Defense centre.
++Escalate the the privilge to root.
admin>sudo su
Enter the root password
root>pmtool status |grep -i Down
root>pmtool status |grep SFData
You would need to check the same thing on the Sensor.
Are you initiating some live traffic. can you create a allow rule with Logging enabled on Top on Defense Centre and see if that works.
Aastha Bhardwaj
That was helpful. Thx
Here is what I have from DC:
root@Sourcefire3D:/Volume/home/admin# pmtool status |grep SFData
SFDataCorrelator (normal) - Running 6052
Command: /usr/local/sf/bin/SFDataCorrelator --nodaemon
PID File: /var/sf/run/SFDataCorrelator.pid
Enable File: /etc/sf/SFDataCorrelator.run
root@Sourcefire3D:/Volume/home/admin# pmtool status |grep -i Down
RUAScheduledDownload - Period 3600 - Next run Thu Nov 19 20:01:15 2015
