SSH does not work in inside interface in ASA
Chieu Dinh
I am able to run ASM but I can't run SSH from inside interface. Does anyone know how can I start to debug the problem? I checked all the setting for enable ssh, I setup it the same way as an instruction.
aaa authentication ssh console LOCAL
ssh 192.168.0.0 255.255.255.0 inside
crypto key generate rsa modulus 1024
What I am missing here? I also have username and password for admin.
15 Replies 15
mahesh18
Level 6
Level 6
Hi Chieu,
Can you provide the output of sh ver?
mahesh
Also check  when you do sh ver
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
Do you see above two things enabled?
Mahesh
Here is the show ver
Result of the command: "show ver"
Cisco Adaptive Security Appliance Software Version 8.2(3)3
Device Manager Version 6.2(5)53
Compiled on Wed 25-Aug-10 21:43 by builders
System image file is "disk0:/asa823-3-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 207 days 6 hours
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1599 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0         : address is 5475.d050.7f46, irq 9
1: Ext: Ethernet0/1         : address is 5475.d050.7f47, irq 9
2: Ext: Ethernet0/2         : address is 5475.d050.7f48, irq 9
3: Ext: Ethernet0/3         : address is 5475.d050.7f49, irq 9
4: Ext: Management0/0       : address is 5475.d050.7f45, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces    : Unlimited
Maximum VLANs                  : 50
Inside Hosts                   : Unlimited
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
Security Contexts              : 0
GTP/GPRS                       : Disabled
SSL VPN Peers                  : 2
Total VPN Peers                : 250
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
Serial Number: JMX1420L3JW
Running Activation Key: 0x8b0edb7c 0x4cee2474 0x34813190 0x90e01484 0x0d2211b2
Configuration register is 0x1
Configuration last modified by cdinh at 15:36:53.519 PDT Mon Jul 29 2013
It was working before I added the new VPN tunnel with another ASA. I did not know what configuration that I had removed to lost this setting.
Hi Chieu,
If it was working before then try to regenerate the keys?
Hope it will not effect any vpn config
ASA1(config)# crypto key zeroize rsa
WARNING: All RSA keys will be removed.
WARNING: All device digital certificates issued using these keys will also be removed.
Do you really want to remove these keys? [yes/no]: yes
thanks
mahesh
It might effect my vpn config
Hi Chieu,
Can you provide the output of sh run ssh?
MAhesh
here is the show run ssh
ssh 192.168.25.0 255.255.255.0 inside
ssh 192.168.16.0 255.255.255.0 inside
ssh 192.168.15.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
Hi Chieu,
Can you remove lines below
and try again.
mahesh
It does not work after I removed these lines:
But you have this line right
ssh 0.0.0.0 0.0.0.0 inside  ?
MAhesh
Yes. I still have ssh 0.0.0.0 0.0.0.0 inside
Hi Mahesh
Do you have any ideas to troubleshooting this problem? Do I need any access list for inside interface?
Hi Chieu,
Seems when you are behind the inside interface of ASA  then you are on same network so you do not need ACL then.
You can try to regenerate the crypto keys as i mentioned earlier.
I could not think anything else for the moment.
MAhesh
