Static NAT problem ASA 5525
szczyrk80
Hi All,
I have a problem with setting up static mapping on 5525 with the latest software,
Configuration attached.
Briefly, that has been implemented on ASA5525 object network sqldr host 192.168.10.205 access-list acl_out extended permit tcp any object sqldr eq 1433 object network sqldr nat (inside,outside) static 158.69.20.23 access-group acl_out in interface outside When checking access-list acl_out I can see some hits when trying telneting that server from outside: access-list acl_out line 4 extended permit tcp any object sqldr eq 1433 (hitcnt=3) 0x6b735618 access-list acl_out line 4 extended permit tcp any host 192.168.10.205 eq 1433 (hitcnt=3) 0x6b735618
Checking what's my IP on server .10.205 still showing global outside address 158.69.20.20 instead of 158.69.20.23
Also can not telnet that server from any external IP on port 1433
Any advice much appreciated
Thank you,
Kind regards,
Sebastian
2 Accepted Solutions
You can use packet-tracer to find the reason:
packet-tracer input outside tcp 1.2.3.4 1234 158.69.20.23 1433
And test the port from the firewall:
ping tcp 192.168.10.205 1433
That's what is expected. The ASA would handle the connection as needed. You need to continue troubleshooting on the server.
7 Replies 7
The main-problem is that your NAT-order is wrong. The dynamic PAT always has to go to the end. You can correct it the following way:
no nat (inside,outside) source dynamic Generic_All interface
nat (inside,outside) after-auto source dynamic Generic_All interface
Hi Karsten,
That works like a charm,
Server now is getting public it as wanted,
However, telnet connection from outside on port 1433 is still failing,
As before I can see hits in access-list,
I have checked that port externally and internally and it is still blocked despite heaving access-list in place
Obviously, firewall on that server etc. all disabled
Is there anything to do with access list?
Thank you,
Hi Karsten,
Thank you for that, my results below:
I used my external ip: 119.158.174.195 (laptop at home)
FW-DR# packet-tracer input outside tcp 119.158.174.195 1433 158.69.20.23 1433
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface inside
Untranslate 158.69.20.23/1433 to 192.168.10.205/1433
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 737, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Do you think that can be a problem:
For interall server IP: 192.168.10.205 results below:
FW-DR# packet-tracer input outside tcp 192.168.10.205 1433 158.69.20.23 1433
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: VPN
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Result:
input-status: up
output-status: up
Action: drop
Drop-reason: (sp-security-failed) Slowpath security checks failed
Thank you
Great, thank you
All working as expected, there is no response on port 1433 because nothing is using it
Creating allow access list for rdp 3389 works like a charm
Thank you for your help !!!
Lates results from ASDM packet tracer
