Static NAT with tcp_max_conns(MAX TCP Connections) & emb_limit(embryonic limit)
imran.moulvi
Hello Experts,
Can someone please clarify the following command for me-
static (VPN,outside) x.x.x.x y.y.y.y netmask 255.255.255.255 tcp 10000 10000
Does this mean that the NAT will be done only for TCP connections and UDP traffic will not NAT?
Jennifer Halim
No, that means that the NAT will be performed for both TCP and UDP, however, the maximum connections and embryonic connections for TCP is 10,000, while for UDP, it's unlimited (as per default).
Jennifer Halim
Thanks for clariyiing that.
