Strange issue with PIX 7.2 (2) Interface Ip addressing
ajupanicker
We bought a new PIX with 7.2(2),We are having issues configuring the IP address and telnet to the PIX from inside network.On the running configuration it shows ip address for the interface but the "show interface" shows "ip address unassigned".
Please see the output.
pixfirewall# sh run
: Saved
PIX Version 7.2(2)
hostname pixfirewall
enable password 8Ry2YjIyt7RRXU24 encrypted names
interface Ethernet0
shutdown
no nameif
no security-level
no ip address
interface Ethernet1
nameif inside
security-level 100
<font color="#FF0000"> ip address 192.168.1.250 255.255.255.0</font>
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
prompt hostname context
: end
pixfirewall# sh int e1
Interface Ethernet1 "inside", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
MAC address 001a.a2a4.8737, MTU 1500
<font color="#FF0000"> IP address unassigned</font>
121660 packets input, 11001073 bytes, 0 no buffer
Received 121856 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/6)
output queue (curr/max blocks): hardware (0/0) software (0/0)
Traffic Statistics for "inside":
121856 packets input, 9287953 bytes
21234 packets dropped
1 minute input rate 2 pkts/sec, 213 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 1 pkts/sec, 124 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
I saw 3 similar queries for the same starange issue on our netpro,but it still remain unanswered.Can somebody please help ?
6 Replies 6
ajupanicker
I am pasting the show version command output here
pixfirewall# sh ver
Cisco PIX Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
Compiled on Wed 22-Nov-06 14:16 by builders
System image file is "flash:/image"
Config file at boot was "startup-config"
pixfirewall up 15 hours 44 mins
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xf
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 001a.a2a4.8736, irq 10
1: Ext: Ethernet1 : address is 001a.a2a4.8737, irq 11
2: Ext: Ethernet2 : address is 000f.a3e9.b028, irq 11
3: Ext: Ethernet3 : address is 000f.a3e9.b029, irq 10
4: Ext: Ethernet4 : address is 000f.a3e9.b02a, irq 9
5: Ext: Ethernet5 : address is 000f.a3e9.b02b, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Failover Only-Active/Standby (FO) license.
Hi .. as you can see in the last line of the 'show version' your PIx is licensed for FO .. this means it needs another one to work correctly .. contact your vendor or Cisco for getting the right license.
"Failover (FO) ? Designed for use in conjunction with a similar Cisco PIX Security Appliance model that has an Unrestricted
license, providing a cost-effective, Active/Standby high-availability solution.
? Provides the same capabilities as the Unrestricted license, except the Failover license does not support
Active/Active failover. Requires presence of similar Cisco PIX Security Appliance model with an Unrestricted
license to operate properly."
I hope it helps .. please rate if it does !!!
Hi Fernando,
It really helps,thanks a lot for this answer.If this is the case,we wont be able to configure this device except from the console session ?,also it can't be used as a stand alone PIX ?
Or is there any possibility that we can get the license from cisco that it can be used as an FO as well as a normal stand alone pix ?
Thanks again for your replies.
You can purchase a license to upgrade from Failover to Unrestricted license from Cisco, or to an Active/Active failover licenese, these are the part numbers :-
o Unrestricted PIX-515-SW-FO-UR=
o Active/Active PIX-515-SW-FO-AA=
Hi Mark,
Thanks for your reply.Wouldn't be possible that you we can assign the ip address's for the interfaces with my existing PIX-515-SW-FO licence and test it ?
You mean the existing licence will not give an option to configure the PIX remotely ?
Guyz,Finally this issue has been fixed with the help of 'googling'.
Issue the command "failover" in the global configuration to change the mode from Standby to Active.Now you will be able to assign IP address for the interface's and it will show the ip address for the "show interface" output.
So,without buying/changing the failover licence,this firewall can be configured through telnet sessions.
