09-05-2013 03:21 AM - edited 03-11-2019 07:34 PM
I have configured tacacs in ASA 5520, it is working fine, I can login into ASA with tacacs credentials..authentication is successfull when tacacs server is unreachable Local authentication is also successfull.....But after that when Tacacs server is reachable again...I am not able to login with tacacs credentials.
Is the the bug of Cisco ASA 5520 software image?
Below are the configurations:
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (inside) host 1.1.1.1
key tacacs_key
aaa authentication enable console TACACS+ LOCAL
aaa authentication http console TACACS+ LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console TACACS+ LOCAL
aaa accounting enable console TACACS+
aaa accounting ssh console TACACS+
aaa accounting command privilege 15 TACACS+
09-11-2013 10:51 AM
Hi Arun,
Can you take captures on inside interface of ASA when problem occurs? Put the captures in pcap.
Paste debug level logs from ASA and logs from ACS when issue is seen.
Sourav Kakkar
09-11-2013 12:27 PM
Hello Arun,
Can you share the following command with us when the AAA authentication against the tacacs+ database is not working
show aaa-server TACACS+ host 1.1.1.1
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
11-07-2017 05:05 AM
