Upgrading ASAs to a newer firmware help
Gonzo1
I've not upgraded our ASAs in a while and need some help doing this.  We have 2 x ASA 5516s with Firepower and they are in an Active/Standby setup.
Here are some details:
  1. I have a TFTP server, but am not sure which firmware to go to, I have done the ASDM, what do you suggest?
  2. I think last time I did the standby ASA first last time and some how failed it over to so it became the primary then did the newly elected standby.
Any simple instructions would be great.
balaji.bandi
Here is the Upgrade Steps :
https://www.cisco.com/c/en/us/td/docs/security/firepower/upgrade/fpmc-upgrade-guide/upgrade_asa_firepower.html
1. Choose the stable release based on your requirement.
2. read the release notes and bugs
3. take backup and store outside the box for safe side.
4. do the upgrade in maitenance window.
5. Upgrade standby
6. check all woring as expected.
7. upgrade primary
8. keep monitor, so no other issue report. then singooff upgrade.
BB
