Will disabling inspect for h323 drop existing h323 sessions on the ASA?
LA-Engineer
I'm trying to troubleshoot some Avaya H323 issues and one of the solutions was to disable inspection for h323:
policy-map global_policy
 class inspection_default
  no inspect h323 h225
  no inspect h323 ras
What I need to know is whether or not applying these commands will drop existing H323 connections.  Or, will inspection be disabled only for future connections?
LA-Engineer
The answer appears to be, no.  None of my phones reregistered after applying this command.
