pbaragur
We're pleased to announce that Interim software 8.5MR1 Interim version 8.5.107.79 is now posted on the Forum.
 Obtaining Pre-Release Software
  1. Please fill software request access form for 8.5MR1 Interim: http://cs.co/85mr1access
  2. Once above step is completed, access to all supporting materials and pre-released software will be made available to Cisco Beta Customers within 24 Hours at
    http://cs.co/85mr1imagerepository
[NOTE:
1. Please make sure to use Aspera Client to download files, if downloading for the first time from
    shares.cisco.com you will be prompted to install Aspera Client on top of Website
2. Also please make sure to check your popup blocker if you are not able to download the code.]
In order for us to track found issues or simply comments or questions you must submit each initial feedback or bug via Feedback form through provided link:
http://cs.co/85mr1feedback
Resolved Caveats
8.5.107.79
CSCve64066       AP is not joining the controller when IP is changed from DHCP to static, for first time
CSCvf33154       Wireless to Wireless multicast failure on Cisco 2800, 3800 APs with WPA-PSK-TKIP
CSCvf81919       3800 AP crash: selipc causing double free
CSCvg07305       No error messages displayed when enabling FRA and RF group Leaders are on different physical WLC's
CSCvg26310       AP 2800 Radio Cores Caused by tx_recovery_failed after FW Beacon Stuck
CSCvg35226       Unable to change Antenna Band Mode to 1562E AP
CSCuz85056       Modifying IP mode from DHCP to Static does not chnage for a scenario
CSCvf05707       MAPs with no children on DFS channels unable to perform fast roaming
CSCvf08426       observed watchdog reset (mrvlfwd) crash on AP2802 with the 8.5.1.190 load
CSCvf22689       8.5 Need WLC show command for sensor reachability verification for non-xor aps
CSCvf27305       8.5.1.201 - AP1815M MAP3 loses connection to controller when wireless client roams to it ...
CSCvf60045       Cisco Controller reloads unexpectedly on "config bleBeaconwhiteList add HomeDepot"
CSCvg22857       FEW - AP access-tunnels drop when WLC switches over
CSCvg31538       IPV6 traffic gets dropped in Encr mobility
CSCvg37134       AP 1800S sensor in most of the cases fails to join the neighbor AP
CSCvg37369       No data is displayed on assurance with 227 WLC image
CSCvg39156       DHCP should not be sent to WAP with AP ->WLC header within EoGRE
CSCvg39437       WGB should forward downstream broadcast traffic within specific vlan
CSCvg43083       Cisco 3800 AP DFS intermittent compliance failures
CSCvg46683       FEW - map server AP entries dropped when WLC switches over again
CSCvg51267       Tunnel not plumbed on the UCS HA standby when peer is in same VLAN
CSCve30380       AP3700 Flex mode AP not advertising Ext. Cap. IE in Assoc Resp
CSCve50340       broadcast-replicate feature does not replicate broadcast to non-native vlans
CSCve60014       Sleeping client entry not getting created after idle timeout
CSCvf05391       wlc not sending delete payload to AP on exclusion client manual deauth
CSCvf12011       Webauth logout fails after standalone - connected
CSCvf21673       Cisco 2800/3800 APs send block ACK packets using disabled data rates
CSCvf23943       FRA is impacted when AP 3800 modules (like AIR-RMVBLE2) are in use
8.5.107.71
CSCuw48090      Cisco 1602 AP 5-GHz radio stop transmitting / receiving frames
CSCux97132       AP starts the Channel Availability Check (CAC) timer after rolling back to a lower bandwidth
CSCuy61155       802.11b inconsistent probe response - band select enabled - 2.4GHz
CSCuz72195       AP Bridge does not forward BPDUs or VTP frames
CSCva59172       RF - Profile paramaters are not pushed for optimised roam
CSCvb57793       AP does not fragment EAP cert correctly
CSCvc50775       Webauth redirection stop working when AP manager is configured on a dynamic interface
CSCvd15449       FRA Probe suppression doesn't work for pre-association client
CSCvd42321       Cisco 1832 AP drops the CAC SIP 486 packet
CSCvd83486       Cisco IW3702UX AP will not join Cisco vWLC after 3+days
CSCvd91770       Trust-DSCP-Upstream broken on Cisco 8.2.151.0 release
CSCve13779       AP2802 Rogue Detection config changed back to "Enabled" after AP reboot
CSCve18213       Foreign WLC leaks IPv6 and IPv4 multicast client traffic out of EoIP tunnel
CSCve33506       Client EAP-TLS handshake does not succeed with AP-COS APs
CSCve39780       1832 ME is dropping some 11a static IP client associations due to DHCP Policy timeout
CSCve47928       Cisco 8.5 release: AP is not joining the Cisco WLC after image upgrade
CSCve51301       Cisco 1850, 1830 AP: Stops beaconing
CSCve56341       Msglog flooding with MUTEX_UNLOCK_FAILED: trace backs
CSCve57121       3800 AP not passing traffic
CSCve57918       WLC IGMP queries not sent consistently
CSCve59671       WLC/ME: RADIUS fail-over does not work when retransmit timeout is not set to default value
CSCve63755       Cisco WLC running 8.4.100.0: Cisco APs fail to join the WLC if it has LSC enabled on it
CSCve64652       AP crash CPU vector after: NZ prev pointer but not running, timer Process="LWAPP CLIENT"
CSCve65242       Cisco 702w AP radio resets with reason code 71
CSCve68039       Some APs cannot join the WLC because the WLC misrecognizes the number of APs
CSCve68787       Cisco AP is not transmitting out the de-auth frame over the air that was received from the WLC
CSCve72187       Micro-Macro transition configuration should be limited to within the defined range
CSCve75022       Cisco WLC does not apply QoS tag upstream from foreign to anchor
CSCve75339       Macro to micro transition threshold is not configurable on Mobility Express
CSCve75515       Configuration backup shows the time instead of the NAT IP
CSCve78449       Cisco 3700 AP: radio d1 reset: Tx jammed
CSCuz59858       Cisco 3500AP (SC1), client association failure - R2H Buffer full
CSCve81269       Clients failed to get connected to the Cisco AP in Flex mode with message as AID already in use
CSCve81314       Clients fails to connect to AID with message as All AID are in use when the AP is in Local mode
CSCve83024       WLC power supply issues not showing up on 360 page
CSCve84906       Traceback observed in Cisco WLC while something is fetched for Flex ACL with AVC
CSCve85321       WGB traffic disruption on missed beacons and no scan or roam
CSCve86627       bridging interface mode get reset to 'access' when configure MeshAP from GUI
CSCve90032       WLC Fabric Enabled Wireless: flooding logs with "Updating MS IPv6[1] Addr" logs
CSCve92127       WLC Data plane reloads unexpectedly on DP core 0 due to WDT
CSCve95309       'WL_IOCTL_SET_MGMT_SEND failed for apr1v0 error Bad address' msg on AP by Radio reset
CSCve96310       Cisco WLC installs certificate without a password. However, WebAuthentication fails.
CSCve96870       wcpd out of memory; AP-COS reloads, or fails to send auth or DHCP response to client
CSCve98689       Repeated CDP-4-DUPLEX_MISMATCH seen 1852 and 3802 APs are connected to 3850 switch.
CSCve98892       DNS lookup for RADIUS/TACACS+ fails because it is queried before the physical port is up
CSCve99696       CPU ACLs are missing after the WLC reload.
CSCvf01433       Cisco 1852 AP fails to send multicast packets to wireless
CSCvf02705       The IP-SGT binding is removed from SXP peer after a WLC redundancy switchover
CSCvf03024       The power constraint value is advertised as 3, though it is configured as 0
CSCvf05046       Cisco 1800,2800,3800 APs: correction in unit of antenna gain in show controller output
CSCvf05427       Cisco 2800/3800 AP cannot use the RX-SOP
CSCvf07062       channel assignment leader shows incorrect value on standby wlc
CSCvf07776       Cisco 2800, 3800 AP - FIQ stopped working due to firmware core dump loop
CSCvf12571       AP2800/3800- CAPWAP tunnel does not restart automatically after primary-base WLCName
CSCvf12728       Cisco 7510 WLC stopped working in SNMP task with no traceback
CSCvf15991       Client data traffic drops AAA override and link-local-bridging are enabled due to timing issue
CSCvf16629       The OUI string updates properly in Cisco 5508 WLC but disappears after a reboot
CSCvf17488       Cisco WLC reloads unexpectedly with task name: mmMaListen on 8.4.100.0
CSCvf22697       Flooding "Invalid checkpoint client ID (0)" message on Standby WLC
CSCvf23182       Radio parameters become blank after setting channel width to 40-above
CSCvf23432       Crash - DOT11-3-OFF_CHN_QUEUE_STUCK:  Flushing off channel Queue recovery acted
CSCvf25015       AP on 8.2.154.62 reloads ENTROPY-0-ENTROPY_ERROR:unable to collect sufficient entropy
CSCvf26207       WLC running 8.0.120.36 faces crash while running airewave director debug
CSCvf27533       3800 Ap in a constant crash reboot loop
CSCvf28800       AP 2800:  8.2.154.67  FIQ crashed due to  aptrace
CSCvf30881       After changing the AP CAPWAP v4 to v6, AP name is changing to default MAC name
CSCvf32021       WLC not marking TID in CAPWAP for TSPEC/TCLASS client after roam it is marked
CSCvf32864       wired client behind MAP(iw3700) is not able to send traffic to destination
CSCvf33081       WLC running 8.3.121.0 is not accepting IPs for NetFlow exporter ending between .224 - .255
CSCvf34744       Correct fix for CSCvc78546 (Zero 801.11e QoS for downstream voice when CAC disabled)
CSCvf37785       On 1810W AP, multicast fails to pass on the LAN port when switchport for 1000M speed
CSCvf38154       Cisco 2800, 3800 APs- Dual DFS Fix that avoids False DFS triggers in HD environment
CSCvf38379       8540, 5520 WLCs won't boot - "System could not find 68xx Nic Card"
CSCvf38544       WLC: Jamaica Country does not add -E Regulatory Domain support for Outdoor APs
CSCvf39106       WLC IPv4 CPU ACL mapping is removed after redundancy switchover
CSCvf41342       HA SSO - Apply Config failed on Standby, Reason:5
CSCvf41485       WLC reloads unexpectedly when entering 'show run-config' command
CSCvf44285       8.3 does not allow use of spaces in Flex group names, no APs showed on GUI for existing names
CSCvf44497       Cisco 2800, 3800 Flex- If there is no RSN IE, yet the AP is advertising both HT and VHT IEs
CSCvf44583       Cisco 2800, 3800 APs transmitting at MCS/802.11n rates to clients with WMM disabled
CSCvf45017       Remote LAN with 1810w in flex not showing client IP
CSCvf45989       WLC DP core 0 hung due to RML interrupt handler
CSCvf47017       AP 2800/3800 AP - not able to boot and get stuck "BootROM: Image checksum FAILED"
CSCvf50387       new AP 1562 crash due to: FIQ/NMI reset
CSCvf50747       When traffic is not initiated by the WLC, the WLC does not check ARP table
CSCvf52008       WLC's GUI hanged and unexpectedly rebooted
CSCvf52723       IOS AP FlexConnect local switching - client cannot pass traffic when using 802.1X + NAC
CSCvf52875       SNMP:Junk characters in place of server ip when image download is initiated from Prime
CSCvf55570       Clients unable to connect when CCKM and FT802.1X are enabled together
CSCvf55741       Cisco 1532 AP cannot use static IP address when configured as mesh AP (MAP)
CSCvf56076       Calibration data stored for channels 40, 149 and 153 are incorrect
CSCvf56556       Guest User role cannot be called properly on the Cisco 2504 WLC platform
CSCvf57305       Issues with 1562s MAP taking a long time to join RAP
CSCvf57360       Wave2 AP clients constantly deleted with active voice traffic and optimized roaming enabled
CSCvf58977       RTU license count taking over Smart Account count
CSCvf59621       Cisco 3800, 2800 AP running 8.3.124.40 release: TxFSM Stuck
CSCvf59685       Cisco 3602i/e AP reloads unexpectedly while failover occurs
CSCvf61110       Implement a knob to enable disable TPC optimization based on Neighbors within an AP group
CSCvf61646       11v BSS Transition Preferred Candidate List Not Included with Radio Policy Set to 802.11a Only
CSCvf61962       WLC crash due high CPU caused by SNMP task
CSCvf61975       WLC reaper not creating proper crash file
CSCvf62670       AP1850/1830 : Stop Rx without beacon drop in noisy environment
CSCvf62929       WLC randomly marks wireless management frames with DSCP CS0 instead of CS6
CSCvf63464       AP show clis seen having previously joined controller capwap tunneled WLAN entries
CSCvf65587       2504 controller not accepting 50 AP evaluation license
CSCvf67467       System crashing as Reaper Reset:Task wipsTask taking too much cpu
CSCvf68648       Dataplane crash when using EoGRE tunnel
CSCvf69070       Aironet2802 marking upstream client traffic with incorrect DSCP values when WMM is disabled
CSCvf71074       AP 1562 Failed to decode discovery response
CSCvf71136       Infra IPv6 AP drops off from the WLC every 4 to 12 hours
CSCvf72352       Rogue APs getting contained or containment pending automatically on the WLC
CSCvf72497       3600 AP dropping over dtls tunnel with 8540 wlc
CSCvf76245       debug client sometimes reports wrong BSSID in (Re)association message
CSCvf76739       2800/3800 AAA override VLAN doesn't work for native VLAN.
CSCvf77787       AP LAG fails using LACP with non-Cisco switches
CSCvf82065       1562 unable to pass multicast joins from RAP to MAPs
CSCvf82117       WLC fails to send complete IPv6 client information to Prime Infrastructure
CSCvf83404       VLAN override on RLAN with FlexConnect Local Switching does not work
CSCvf83733       WLC detects IDS Signature attack even if Signature Processing is disabled
CSCvf84211       WLC dataplane crash due to core 0 hung and RML interrupt handling
CSCvf84816       AP1810W Kernel Panic crash PC is at 0x4 LR is at _ieee80211_free_node+0x264/0x4b4
CSCvf86035       1815w Kernel Panic wlan_channel_frequency+0x10/0x18 LR  acfg_get_client_info+0x84/0x264
CSCvf86148       3800 ap crash 8.3.124.40
CSCvf87731       WLC Crash during AP join failure
CSCvf88091       Clients behind 3rd Party WGB fail DHCP post upgrade to 8.0.150.0
CSCvf89334       OpenDNS information is lost when Master AP fails over to the new one
CSCvf95036       1850 radio firmware crash at 0x009A4859, QCA 03132454
CSCvf97662       AP801/AP802 not support DTLS data encryption but it's configrable
CSCvg01740       Deauth reason pulled from association response code wrongly
CSCvg01874       Unable to add LSC CA Certificate on wlc GUI
CSCvg08894       3802 AP crash Watchdog reset reason: capwapd 8.2.161.0
CSCvg20439       1562 is dropping downlink unicast messages, making connectivity difficult across mesh link
CSCvg21845       WLC crash - Task Name: SXP SOCK
CSCvg29019       AP18xx : Bypassed scan in returning to DFS channel after blacklist timeout
CSCvg10793        Key Reinstallation attacks against WPA protocol
CSCvf47808         Key Reinstallation attacks against WPA protocol
CSCva18887       ME : IOS AP flash corruption issue
CSCvb64056       nat-pat & central DHCP is disabled on AP after reloading AP
CSCvc71012       Error in retrieving number of mDNS policies with command "show mdns policy service-group"
CSCvd09394       AP3700: Tx util values are not changed
CSCvd21375       8.5.1.71 - 1562 RAP doesn't show (DFS scan in process) like Crete does ...
CSCvd64928       System stopped working on PMIPV6_Thread_0 during creation of LMA entry
CSCvd80240       FlexConnect AP sends associate response with wrong HT capabilities
CSCvd90160       AP2800 sending announce as 0 in Reassociation response in FlexMode in FT and adaptive FT
CSCvd95557       For Non-DPAA AP Model, client stuck in Authentication Mode while associating
CSCve18089       vWlc:Data switching role changes from local to central upon roaming b/w click-AP's
CSCve28491       APs in Flex mode with interface configured trunk with multiple VLANs missing links to switch
CSCve31474       WGB HSR 802.11v neighbor report error message when Infrastructure MFP is enabled
CSCve44977       WLC 8.5.1.138 Dual Band radios showing incorrect suggested mode
CSCve56210       Uva: Observed command-timeout while XOR radio was in Sensor mode
CSCve56404       Cisco 8.5: Cisco XOR radio configured to Sensor mode using GUI has operational state down
CSCve61201       When tput improves above earlyliftthreshold, UE authentication int successful
CSCve66810       eca-ios-ap: data acl and cwa redirect acl not pushed to ios-ap's
CSCve67164       eca-ios-ap: Wrong webauth status at ios-ap
CSCve67229       Sanity:  ap1800i rebooted error msg : apsw_watchdog about to reboot with reason: wcpd
CSCve69442       Mobility with DTLS: no PMTU discovery packets sent
CSCve81183       Cisco 2800, 3800 - Rx hang in 8.2.154.17 release
CSCve83915       32 chars match role string is not accepting in CLI unlike in GUI
CSCve86203       eca-ios-ap: downstream bssid/client qos policing and marking not effective (CD21)
CSCve88087       AP18xx WMM parameters not pushed to radio FW, QCA 02998094
CSCve88574       vEWLC AP-SSO: Data-keepalive sent to Old Active MAC and dropped at controller after SSO
CSCve89376       Cisco Wave1 APs sends RA periodically when EoGRE tunnel profile is added to the AP
CSCve91836       AP crashed when running Multicast Flex Mode script
CSCve93715       ewlc: click-os 3802 AP crash -capwapd
CSCve96480       IOS AP stopped working when it is changed from sensor mode.
CSCve99067       Assurance:  JWS Token creation failed error on WLC
CSCve99763       8.5.1.176 - Crete MAP2s experience roaming issues ...
CSCvf00877       8.5: cmdtimeout when xor in sensor mode, band mismatch errors
CSCvf04412       2800/3800 AP acting as ME stopped working due to watchdog reset (OOM) after 23 days up time
CSCvf05003       eWLC:Mobilitty Tunnels are flapping post SSC integration if aireos is server
CSCvf05776       Target assert  XXXXXXXX WAITING FOR STOP EVENT on Cisco 1810 AP
CSCvf07189       8.5 Incorrect prompt after executing any CLI with (y/n) option
CSCvf07775       Cisco 2800,3800 AP - Kernel panic FIQ or NMI - Panic in click
CSCvf09441       PMIPv6 MAG is not initialized in the backend
CSCvf10157       Wism WLC stopped working with emWeb in 8.5.1.183 build
CSCvf10810       Partial collection failure for Mobility express
CSCvf11433       Sanity:core-mrvlfwd and core-wcpd found in ap3800 with 8.5.1.192
CSCvf12246       Mesh: Assoc ID is always passed as 1 to all clients
CSCvf12355       FEW : Unknown Clients IPV4 address on WLC when Clients joins on IOS 3700 AP
CSCvf16842       Tunnel Gateway (TGW) in Cisco 3802 AP comes up only after the Heartbeat interval expires
CSCvf17085       The radio of Cisco 3800 series AP stopped working after an image reload
CSCvf17133       8.3MR3:"config dhcp address-pool test 178.1.0.1 178.1.0.100" hits "Invalid scope specified."
CSCvf17294       8.2.154.61 : Radio Reset, wlChkAdapter(2686): regval ffffffff for wifi0
CSCvf18505       When WLC adaptive/fastlane is disabled, the CCX IE is missing in probe response Wave 2 APs
CSCvf18545       Farallon AP image with swim support
CSCvf19717       Modification of Single host-multihost-mab enable/disable results in rlan removal
CSCvf19891       Cisco 3800 and 2800 series APs stopped working when an SKB from Linux host was freed twice.
CSCvf20997       Hotspot getting enabled with open security in WLC
CSCvf22342       Cisco 3800, 2800 AP running 8.2.154.64 release: TxFSM Stuck
CSCvf22977       Not able to delete Radius Auth server with RFC3576 enabled  form CLI.
CSCvf23193       eCA : Assurance token and URL details are not pushed to APs in Sensor mode
CSCvf23812       AP2800/38008.5: FIQ reset on ME WLC
CSCvf25062       AP3800 on 8.3.124.17[cmd mismatch] wifi0: Host Cmd:0x9201 F/W Cmd:0x8001 Last:0x801d
CSCvf28913       WLC FRA configuration menu VERY confusing
CSCvf31767       AP group entry duplicated, cannot delete AP group, access existing AP groups
CSCvf33168       FEW:  all access-tunnels taken down when fabric interface deleted
CSCvf33658       Observed L2 and L3 roam failure more than 5% in polaris-longevity with 1800 series AP
CSCvf33937       system crash from do_pingInet task
CSCvf38293       8.3.124.25: AP3800 Radio 0 stopped
CSCvf39202       3600 AP continuously reloading after data dtls config mapped to AP
CSCvf41057       Clients QoS level changes automatically to silver from gold during local authentication
CSCvf41909       XOR radio is not set to lowest Tx power after moving to 5-GHz band by FRA
CSCvf44061       SNMP get or walk on device for bsnAPBridgingSupport returns ENABLE for AP2800/3800
CSCvf46047       AP: C3700 image upgrade support from 8.3 to 8.6
CSCvf46715       Cisco 3800 AP running 8.3.124.31: Kernel panic seen on alpha
CSCvf47198       1815M-Mesh: Fixed backhaul rate configuration does not work
CSCvf48180       Beacon stuck on 2.4GHz band radio
CSCvf51254       8.3MR3: MU-MIMO: Radio 1 crash from muTxDone()
CSCvf51690       DHCP option 60 string is not showing in wired capture in DHCP request for 2800 series AP
CSCvf51780       AP3504 WLC crashed during external webauth redirection with MAX length URL
CSCvf55262       Corrupted packets during awpp link formation
CSCvf56465       wlc does reflect 400 error codes
CSCvf57477       AP 3800 Radius Server config is getting changed when upgrading from 8.3.124.38 to 8.6.1.80
CSCvf57859       Ceiling not working if DSCP sent is higher than metal policy of WLAN
CSCvf59630       XOR radio does not move to 5GHz/Monitor bands after being marked redundant
CSCvf60313       Sanity:Core file found on ap1560 with 8.3.124.41
CSCvf64268       ME: Once opening and closing the DHCP lease the crash was occured to the device
CSCvf65100       AP3800E/2800E- Apple Broken Antenna Detection ant_mon_detection_time_secs initialization
CSCvf65574       IOS AP flap upon switchover and client summary table not showing client with IOS AP
CSCvf68673       AP is doing reassembly of uplink packets, which is causing ping fail for jumbo pkts
CSCvf68674       8.5MR1: ptr_meshFileCfg.cfg.convMethod value = 3 is out of range min = 0 and max = 2 upgrade
CSCvf69071       WLC 3504 factory default license issue
CSCvf71897       3800E All antennas are reporting weak signal. A is enabled and BCD disabled for weak-RSSI
CSCvf72997       8.6: 1832 kernel panic
CSCvf75532       AP-Group:AP group name configuration is not persistent after AP reload when it is configured from AP
CSCvf75869       2800/3800 radio0 crashing in longevity due to 3rd party FW issue(s)
CSCvf76161       ME: Master AP running with 100% CPU Utilization
CSCvf76528       wlc(5520) crashed with Task Name:\tapfMsConnTask_4
CSCvf77017       [vEWLC]:2700 AP always send DSCP 32 in Upstream for IPv6 Traffic
CSCvf80317       FEW - map server AP entries dropped when WLC switches over
CSCvf81993       Sensor heartbeat stopped working when AP in sensor mode for 1832I after some time
CSCvf82214       8.6.1.97 WLC image does not log msglog
CSCvf82379       8.5.107.23 - Standby WLC (AIR-CT5508-K9) crashing with haSSOServiceTask0
CSCvf83594       Client moving to RUN state from webauth reqd after reassoc request
CSCvf84540       Cisco 3700 AP: radio d1 reset: Tx jammed, probably beacon was not really sent by Hw
CSCvf85093       Downstream policy-map removed from bssid target after controller switchover
CSCvf85489       AP is not able to join the WLC with LSC enabled
CSCvf85758       Data path flaps on HA switchover
CSCvf87646       AP 2800/3800 Sniffer mode: Sees frequent kernel panic crashes
CSCvf89222       8.5.107.30: standby wlc-8510 - crashed with rmgrMain due to IPC timeout has occurred multiple times
CSCvf89413       FEW Sanity: Client stuck in DHCP-REQD state after enabling fabric
CSCvf92627       8.5.107.34 AP - AP3802E-B - AP crashed due to watchdog reset(with reason: out to reboot with r)
CSCvf94486       For 802.11ac, client estimated throughput drops drastically after connecting
CSCvf94574       Not able to create ipsec profile
CSCvf94707       After CoA, when client connects within backoff timer, WLC sends Access Request
CSCvf95048       AP group: When RLAN AP moves from old AP group to new AP group,old RLANs are still maintained
CSCvf96146       IRCM 16.7.1:Mobility tunnels are flapping between vEWLC and 5508
CSCvf97201       8.3MR3: MU-MIMO: Radio 1 crash from muTxDone() - more trigger in addition to fixes in CSCvf51254
CSCvg01352       IPv4 traffic drops with "Packet needs to be fragmented but DF bit is set" and MTU mismatch
CSCvg01771       AP1815 / TSN Wifi / Star Wifi: Fail to boot after power-off during u-boot upgrade
CSCvg01883       ClickOs:client association failed with A radio
CSCvg02335       https communication is not enabled in Farallon image download
CSCvg04022       Encrypt mobility enable/disable fails with HA from GUI
CSCvg04081       AP2800 sending announce as 0 in Reassociation response in FlexConnect Mode in FT and adaptive FT
CSCvg04758       Control Path flaps post switchover
CSCvg07438       AP3800: Low throughput due to packet drops in AP in both fragmented and non-fragmented packets
CSCvg07783       Vulcano New P3 modules are not getting dhcp address with AP2800/3800 VE AP. The module is up.
CSCvg08820       Client failed to join Click-AP with A radio alone in local mode
CSCvg12223       Flex mode- WLC does not send all neighbors for a client
CSCvg13374       CCO download DNS breaks after poll and and manually configuring to invalid DNS server
CSCvg14346       WLC- is flagging Misc_Reason 0x9 as an Invalid Apple Reason Code but displays proprietary failure
CSCvg18366       AP hostapd deleting client entry when client goes to FWD state in WCPD
CSCvg18978       Sensor: AP2802I when in radio as sensor radio 0 crash
CSCvg23317       [ECA-SIT]Join Request- PMTU -NOP Payload Parsing issue with Click APs
CSCvg27595       Sensor: 5G radio results in AP2800/3800 XOR have default connectivity values
CSCvg29907       AP 3800/2800 8.5.107.61 AP sending wrong BSSID in the Request,Identity packet
CSCvg30754       Hyperlocation: AP join issues
CSCvg31499       AP 3800/2800 8.5.107.57 and .61 when AP is in flex mode, AP crashed due hostapd process.
CSCvg33285       Sensor : AP2802i : Synthetic tests stops during longivity run
CSCvg33908       AP3800/2800: Apple Broken antenna detection feature won't work without NDP frames
CSCvg35961       8.5MR1: AP2702 radio reset and rcore - rec fail
CSCve12846       Flex mode AP18xx not prioritizing packets based on QoS Map
CSCve13886       WPS signature is getting disabled upon upload or download
CSCve69973       2800/3800 - Throttle Assoc requests to WLC
CSCve79184       1832,1810 AP doesn't send the proper DSCP values to the wlc(data dtls) (upstream QoS marking rework)
CSCvf01576       Cisco 3504 WLC is not generating a crash file.
CSCvf07640       [5520] Setting an IPv6 address for primary-base on an AP from WLC cuts off last characters      after ::
CSCvf16340       8.3MR3:After WLC upgraded to  8.3MR3, Hydra shows "host/RAM_fw Build Ver Mismatch: H:0x47, F:0x5 !"
CSCvf16466       3802 AP sending incorrect DFS channel list to WLC
CSCvf19926       8.3MR3:OSAPI-3-MSGQ_RUNNING_HIGH: [PA]osapi_msgq.c:926 Message queue BCAST-DATA-Q  is nearing full.
CSCvf30035       wlc crashed due to SXP CORE not releasing lock
CSCvf29208       AP2800/3800/18xx-Mesh: Fixed backhaul rate issues.
CSCvf30828       ME: 1815M AP crashes when clients connecting to AVC enabled WLAN
CSCvf31054       continuous FIQ/NMI reset crash for 3802 ap when xor in sensor mode
CSCvf34480       Uva FEW Cheeta-AP loosing flex-avc-profile config if one out of 2 WLAN disabled
CSCvf38393       NDP on 2800/3800 not transmitting at Correct Power on 802.11b/g/n Channels
CSCvf40071       WIPS engine gets disabled on 2800 after AP reboot
CSCvf41587       3800I : {watchdogd} apsw_watchdog about to reboot with reason: wcpd
CSCvf43759       issue 'no bvi-vlanid' on WGB does not cast IAPP message to refresh BVI vlan id on AP
CSCvf47744       ping fail between routers after route setup with radio link
CSCvf49632       Capwapd crashed after enabling capwap payload debug
CSCvf60009       Ethernet daisy chain IW3702 GE1 1Gbps reload same time when configured speed 100 & duplex full
CSCvf69869       In new mobility with NAT, Client connected to foreign is unable to communicate
CSCvf69955       8.5.103.0 - Kernel Panic seen on 1542 Mesh APs
CSCvf95503       11r roam flexconnect local switch OTA FT-8021x fails intermittently on Corsica
CSCvg10680       DTLS handshake takes more time to get established successfully
