![](https://community.cisco.com/html/assets/img_tile-default.png)
Hi, All guy.
I bought two new cisco router 4431. But they alway reboot after I used they in core network(I have been scolded by my boss many times for this fault.)
The story begins:
command
show memory summary
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 7F887A7CF010 1728067312 1503841136 224226176 223626200 209683716
lsmpi_io 7F887A0CD1A8 6295128 6294304 824 824 412
Dynamic heap limit(MB) 1000 Use(MB) 800
If "Dynamic heap limit" Use(MB) 800. System will occur error information.
logg info
2020/8/13 2:26 Local7.Critical 10.10.10.252 2391: *Aug 13 02:28:02.605: %SYS-2-MALLOCFAIL: Memory allocation of 8404 bytes failed from 0x7FD257A8671F, alignment 8
2020/8/13 2:26 Local7.Critical 10.10.10.252 2392: Pool: Processor Free: 1087672 Cause: Memory fragmentation
2020/8/13 2:26 Local7.Critical 10.10.10.252 2393: Alternate Pool: None Free: 0 Cause: No Alternate pool
2020/8/13 2:26 Local7.Critical 10.10.10.252 2394: -Process= "SNMP ENGINE", ipl= 0, pid= 569
2020/8/13 2:26 Local7.Critical 10.10.10.252 2395: -Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7FD24E675000+94055EE :7FD24E675000+9400DEC :7FD24E675000+93FBA2A :7FD24E675000+941171F :7FD24E675000+906BFB1 :7FD24E675000+9062F79 :7FD24E675000+A27BD30 :7FD24E675000+9068964 :7FD24E675000+902D30B :7FD24E675000+9011822 :7FD24E675000+90525EE
2020/8/13 2:26 Local7.Critical 10.10.10.252 2396: *Aug 13 02:28:09.722: %LICENSE-2-VLS_ERROR: 'VLSnotifyBirthAndExpiryEvents' failed with an error - rc = 25 - 'Error[25]: Could not understand the message received from license server on host "no-net".
2020/8/13 2:26 Local7.Critical 10.10.10.252 2397: Client-server version mismatch?
2020/8/13 2:26 Local7.Critical 10.10.10.252 2398: '
2020/8/13 2:26 Local7.Critical 10.10.10.252 2399: -Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7FD24E675000+638C41C
2020/8/13 2:26 Local7.Critical 10.10.10.252 2400: *Aug 13 02:28:32.864: %SYS-2-MALLOCFAIL: Memory allocation of 8404 bytes failed from 0x7FD257A8671F, alignment 8
2020/8/13 2:26 Local7.Critical 10.10.10.252 2401: Pool: Processor Free: 1090656 Cause: Memory fragmentation
2020/8/13 2:26 Local7.Critical 10.10.10.252 2402: Alternate Pool: None Free: 0 Cause: No Alternate pool
2020/8/13 2:26 Local7.Critical 10.10.10.252 2403: -Process= "SNMP ENGINE", ipl= 0, pid= 569
2020/8/13 2:26 Local7.Critical 10.10.10.252 2404: -Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7FD24E675000+94055EE :7FD24E675000+9400DEC :7FD24E675000+93FBA2A :7FD24E675000+941171F :7FD24E675000+906BFB1 :7FD24E675000+9062C15 :7FD24E675000+A178CF7 :7FD24E675000+A178E26 :7FD24E675000+A178ED6 :7FD24E675000+A177061 :7FD24E675000+A176E81 :7FD24E675000+9068964 :7FD24E675000+902D30B :7FD24E675000+9011822 :7FD24E675000+90525EE
If "Dynamic heap limit" Use(MB) 1000. System close all process. In that time, I can't use vty remote to router. But console still active. Then I use "show run" command from console can't seen any output information. For normal, We can seen all running-config that we configure before.
command
show run
XX-R252#
*Aug 13 09:55:31.558: %SYS-2-MALLOCFAIL: Memory allocation of 524292 bytes failed from 0x7FD255B46FCB, alignment 8
Pool: Processor Free: 1263160 Cause: Memory fragmentation
-Process= "Exec", ipl= 0, pid= 3
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7FD24E675000+94055EE :7FD24E675000+93FB821 :7FD24E675000+74D1FCB :7FD24E675000+6DDAF1E :7FD24E675000+6DDBDAB :7FD24E675000+6DDBCB6 :7FD24E675000+6D43012 :7FD24E675000+6CA07B4 :7FD24E675000how run +6C9F85D :7FD24E675000+6C9DB4A :7FD24E675000+A5D5C89 :7FD24E675000+6CBB460| sec
XX-R252#show run | section ip route
XX-R252#show run
XX-R252#show run
XX-R252#show ver
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 15:19 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
XX-R252 uptime is 1 week, 3 days, 9 hours, 8 minutes
Uptime for this control processor is 1 week, 3 days, 9 hours, 9 minutes
System returned to ROM by reload
System image file is "bootflash:/isr4400-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx appxk9 Permanent appxk9
uc None None None
security securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4431/K9 (1RU) processor with 1687555K/6147K bytes of memory.
Processor board ID FTX1912AHVZ
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7057407K bytes of flash memory at bootflash:.
But I can used "show start" command and it normal to output
XX-R252#show run
XX-R252#show s
*Aug 13 09:56:01.670: %SYS-2-MALLOCFAIL: Memory allocation of 524292 bytes failed from 0x7FD255B46FCB, alignment 8
Pool: Processor Free: 1263448 Cause: Memory fragmentation
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7FD24E675000+94055EE :7FD24E675000+93FB821 :7FD24E675000+74D1FCB :7FD24E675000+6DDAF1E :7FD24E675000+6DDBDAB :7FD24E675000+6DDBCB6 :7FD24E675000+6D43012 :7FD24E675000+6CA07B4 :7FD24E675000tar
XX-R252#show startup-config
Using 8487 out of 33554432 bytes
! Last configuration change at 17:47:15 UTC Wed Aug 5 2020 by gavin
version 15.4
service unsupported-transceiver
no platform punt-keepalive disable-kernel-core
hostname XX-R252
After "Dynamic heap limit" Use(MB) 1000. That mean is Dynamic heap limit full. I cann't used console to control and config
logg from console
%% Unable to create EXEC - no memory or too many processes
*Aug 19 07:20:13.735: %SYS-2-CFORKMEM: Process creation of Exec failed (no memory). -Process= "TTY Background", ipl= 0, pid= 73
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7F88E29D5000+94354A8 :7F88E29D5000+943B769 :7F88E29D5000+6C5A1F6 :7F88E29D5000+6C74643 :7F88E29D5000+6C73B65
*Aug 19 07:20:21.741: %SYS-2-MALLOCFAIL: Memory allocation of 52100 bytes failed from 0x7F88ECB8A9C4, alignment 4096
Pool: Processor Free: 670984 Cause: Memory fragmentation
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7F88E29D5000+94055EE :7F88E29D5000+93FD55B :7F88E29D5000+A1B59C4 :7F88E29D5000+B21D7C5 :7F88E29D5000+9434F81 :7F88E29D5000+943B769 :7F88E29D5000+6C5A1F6 :7F88E29D5000+6C74643 :
*Aug 19 07:20:38.764: %LICENSE-2-VLS_ERROR: 'VLSnotifyBirthAndExpiryEvents' failed with an error - rc = 25 - 'Error[25]: Could not understand the message received from license server on host "no-net".
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7F88E29D5000+638C41C
*Aug 19 07:20:54.973: %SYS-2-MALLOCFAIL: Memory allocation of 8404 bytes failed from 0x7F88EBDE671F, alignment 8
Pool: Processor Free: 688848 Cause: Memory fragmentation
-Traceback= 1#ddab2eb189b4d28f8702a18c47fe3324 :7F88E29D5000+94055EE :7F88E29D5000+9400DEC :7F88E29D5000+93FBA2A :7F88E29D5000+941171F :7F88E29D5000+906BFB1 :7F88E29D5000+9062F79 :7F88E29D5000+90117EB :7F88E29D5000+90525EE
-----This time I break off the power and reconnect power cable by myself
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(2r)S, RELEASE SOFTWARE
Copyright (c) 1994-2014 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
Cisco ISR4431/K9 platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Warning: filesystem is not clean
File size is 0x1944c508
Located isr4400-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin
Image size 423937288 inode num 13, bks cnt 103501 blk size 8*512
Boot image size = 423937288 (0x1944c508) bytes
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated d4206167:6dd3e0e1:f1b5b5b7:e4394cff:8637494f
expected d4206167:6dd3e0e1:f1b5b5b7:e4394cff:8637494f
RSA Signed RELEASE Image Signature Verification Successful.
Package Load Test Latency : 8939 msec
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 9 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 10 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 14 seconds, expected max time 10 seconds
%IOSXEBOOT-4-BOOT_SRC: (rp/0): mounting /boot/super.iso to /tmp/sw/isos
Aug 19 07:24:58.500 R0/0: %FLASH_CHECK-3-DISK_QUOTA: Flash disk quota exceeded [free space is 1350496 kB] - Please clean up files on bootflash.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
software.
export@cisco.com.
cisco ISR4431/K9 (1RU) processor with 1687596K/6147K bytes of memory.
Warning: When Cisco determines that a fault or defect can be traced to
the use of third-party transceivers installed by a customer or reseller,
then, at Cisco's discretion, Cisco may withhold support under warranty or
a Cisco support program. In the course of providing support for a Cisco
networking product Cisco may require that the end user install Cisco
transceivers if Cisco determines that removing third-party parts will
assist Cisco in diagnosing the cause of a support issue.
NHRP MIB is not enabled: Trap generation suppressed
However, configuration changes effective
Press RETURN to get started!
*Aug 19 07:25:25.488: pak_debug_init: Successfully initialized pak debug trace buffer
*Aug 19 07:25:33.118: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 19 07:25:34.823: adsl_ifmib_init
*Aug 19 07:25:34.896: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 19 07:25:34.897: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 19 07:25:34.897: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 19 07:25:34.897: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 19 07:25:37.112: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 19 07:25:37.165: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 19 07:25:37.165: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 19 07:25:37.166: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Aug 19 07:25:37.166: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Aug 19 07:25:00.321: %CMRP-3-PFU_MISSING:cmand: The platform does not detect a power supply in slot 3
*Aug 19 07:25:14.733: %EVUTIL-6-PREREQUISITE:cmcc: Preferred library is absent
*Aug 19 07:25:20.922: %CMLIB-6-THROUGHPUT_VALUE:cmand: Throughput license found, throughput set to 500000 kbps
*Aug 19 07:25:21.635: %CPPHA-7-START:cpp_ha: CPP 0 preparing ucode
*Aug 19 07:25:21.660: %CPPHA-7-START:cpp_ha: CPP 0 startup init
*Aug 19 07:25:30.285: %CPPHA-7-START:cpp_ha: CPP 0 running init
*A.ug 19 07:25:30.558: %CPPHA-7-READY:cpp_ha: CPP 0 loading and initialization complete
*Aug 19 07:25:30.679: %IOSXE-6-PLATFORM:cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Aug 19 07:25:40.118: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.10.125 port 0 CLI Request Triggered
*Aug 19 07:25:40.762: %LINK-5-CHANGED: Interface GigabitEthernet0/0/3, changed state to administratively down
*Aug 19 07:25:40.785: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 19 07:25:40.792: %IOSXE_
User Access Verification
Username:
Before this problem I removed all traffice to old cisco router. And removed LAN cables from this faulty router.Only one Wan cable is reserved for convenient management. And I used my laptop computer and console cable connect to this router.Start troubleshooting from now on. I found
Command
show flash:
XX-R252#show flash:
-#- --length-- ---------date/time--------- path
1 4096 Aug 18 2020 16:55:41 +00:00 /bootflash/
2 16384 Mar 19 2015 14:40:10 +00:00 /bootflash/lost+found
3 4096 Aug 06 2020 09:10:05 +00:00 /bootflash/core
4 4096 Mar 19 2015 14:41:36 +00:00 /bootflash/core/modules
5 67500028 Jul 08 2020 00:54:54 +00:00 /bootflash/core/RP__cpp_ha_top_leve_29968_1594169665.core.gz
6 1435133986 Jul 12 2020 01:49:51 +00:00 /bootflash/core/kernel.rp_RP-ISR4400_0_20200712014951.core.gz
7 62944600 Jul 08 2020 00:59:21 +00:00 /bootflash/core/RP__cpp_ha_top_leve_29973_1594169933.core.gz
8 62923017 Jul 08 2020 01:05:16 +00:00 /bootflash/core/RP__cpp_ha_top_leve_29474_1594170289.core.gz
9 62955967 Jul 08 2020 01:20:16 +00:00 /bootflash/core/RP__cpp_ha_top_leve_29881_1594171189.core.gz
10 62920821 Jul 08 2020 01:29:21 +00:00 /bootflash/core/RP__cpp_ha_top_leve_29940_1594171734.core.gz
11 62935595 Jul 08 2020 01:33:46 +00:00 /bootflash/core/RP__cpp_ha_top_leve_30046_1594171998.core.gz
12 62923902 Jul 08 2020 01:38:13 +00:00 /bootflash/core/RP__cpp_ha_top_leve_30051_1594172266.core.gz
13 62923250 Jul 08 2020 01:42:38 +00:00 /bootflash/core/RP__cpp_ha_top_leve_30132_1594172531.core.gz
14 62932726 Jul 08 2020 01:47:02 +00:00 /bootflash/core/RP__cpp_ha_top_leve_30227_1594172795.core.gz
15 62921006 Jul 08 2020 01:51:27 +00:00 /bootflash/core/RP__cpp_ha_top_leve_30279_1594173059.core.gz
16 1434746316 Jul 10 2020 08:56:04 +00:00 /bootflash/core/kernel.rp_RP-ISR4400_0_20200710085604.core.gz
17 1433489361 Jul 11 2020 15:59:40 +00:00 /bootflash/core/kernel.rp_RP-ISR4400_0_20200711155940.core.gz
18 4096 Aug 13 2020 10:00:38 +00:00 /bootflash/.prst_sync
19 4096 Mar 19 2015 14:41:36 +00:00 /bootflash/.rollback_timer
20 36864 Aug 18 2020 08:13:03 +00:00 /bootflash/tracelogs
21 44610 Aug 17 2020 17:26:28 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200817172628.gz
22 176 Aug 13 2020 09:59:53 +00:00 /bootflash/tracelogs/inst_compmatrix_R0-0.log.gz
23 43561 Aug 05 2020 11:55:11 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200805115511.gz
24 43649 Aug 06 2020 02:42:26 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200806024226.gz
25 44120 Aug 06 2020 17:27:40 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200806172740.gz
26 44329 Aug 07 2020 08:17:05 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200807081705.gz
27 44351 Aug 07 2020 23:05:39 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200807230539.gz
28 43702 Aug 12 2020 21:29:15 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200812212915.gz
29 44747 Aug 17 2020 02:38:34 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200817023834.gz
30 344 Aug 13 2020 10:05:22 +00:00 /bootflash/tracelogs/plogd_F0-0.log.gz
31 44323 Aug 08 2020 13:53:24 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200808135324.gz
32 181 Aug 13 2020 10:00:11 +00:00 /bootflash/tracelogs/inst_issu_comp_check_R0-0.log.gz
33 228 Aug 13 2020 10:00:10 +00:00 /bootflash/tracelogs/inst_tdlresolve_R0-0.log.gz
34 122 Aug 13 2020 10:00:12 +00:00 /bootflash/tracelogs/inst_issu_switchover_R0-0.log.gz
35 48295 Aug 14 2020 15:32:38 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200814153238.gz
36 44140 Aug 09 2020 04:41:58 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200809044158.gz
37 44318 Aug 09 2020 19:26:03 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200809192603.gz
38 44370 Aug 10 2020 10:15:07 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200810101507.gz
39 44571 Aug 11 2020 01:03:01 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200811010301.gz
40 189 Aug 13 2020 09:59:57 +00:00 /bootflash/tracelogs/inst_publish_retrieve_sw_sets_R0-0.log.gz
41 44876 Aug 11 2020 15:51:36 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200811155136.gz
42 44044 Aug 12 2020 06:40:10 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200812064010.gz
43 115 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/binos_log_R0-0.log.9278.20200813095706
44 938 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/bsm_R0-0.log.20392.20200813095706
45 171 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2115_R0-0.log.gz
46 4718 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/bsm_pmanlog_R0-0.log.19830.20200813095706
47 210 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.9884.20200813095706
48 193 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/chasync_R0-0.log.21414.20200813095706
49 4929 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/btrace_rotate_sh_pmanlog_R0-0.log.20013.20200813095706
50 28713 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/droputil_9056_R0-0.log.10767.20200813095706
51 340 Aug 13 2020 10:05:27 +00:00 /bootflash/tracelogs/plogd_0-0.log.gz
52 4532 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/flash_check_sh_pmanlog_R0-0.log.20580.20200813095706
53 435 Aug 13 2020 09:57:06 +00:00 /bootflash/tracelogs/flash_mon_R0-0.log.21628.20200813095706
54 2210 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/fman_rp_R0-0.log.21692.20200813095707
55 172 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2114_R0-0.log.gz
56 4188 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/fman_rp_pmanlog_R0-0.log.20843.20200813095707
57 882729 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/hman_R0-0.log.22548.20200813095707
58 4038 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/hman_pmanlog_R0-0.log.22110.20200813095707
59 116 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.21263.20200813095707
60 116 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.21461.20200813095707
61 3165 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/lman_R0-0.log.23734.20200813095707
62 4032 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/lman_pmanlog_R0-0.log.23125.20200813095707
63 116 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/oom_R0-0.log.21266.20200813095707
64 9615 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/pcscd_service_sh_pmanlog_R0-0.log.23286.20200813095707
65 44790 Aug 18 2020 08:13:03 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200818081303.gz
66 211 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/periodic_R0-0.log.24650.20200813095707
67 4528 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/periodic_sh_pmanlog_R0-0.log.23541.20200813095707
68 9734 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/plogd_R0-0.log.24493.20200813095707
69 4082 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/plogd_pmanlog_R0-0.log.23877.20200813095707
70 1128 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/psd_R0-0.log.24573.20200813095707
71 4135 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/psd_pmanlog_R0-0.log.24048.20200813095707
72 1895 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/psvp_R0-0.log.19367.20200813095707
73 12866 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/pvp_R0-0.log.19426.20200813095707
74 35832 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/reflector_9055_R0-0.log.10773.20200813095707
75 10693 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/smand_R0-0.log.25501.20200813095707
76 4454 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/smand_pmanlog_R0-0.log.24934.20200813095707
77 5203 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/sort_files_by_inode_sh_pmanlog_R0-0.log.25162.20200813095707
78 1388 Aug 13 2020 09:57:07 +00:00 /bootflash/tracelogs/vman_R0-0.log.26351.20200813095707
79 3900 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/vman_pmanlog_R0-0.log.25771.20200813095708
80 157 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/binos_log_R0-0.log.9278.20200813095708
81 252 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.9884.20200813095708
82 4096 Mar 19 2015 15:03:01 +00:00 /bootflash/tracelogs/modules
83 235 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/chasync_R0-0.log.21414.20200813095708
84 28755 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/droputil_9056_R0-0.log.10767.20200813095708
85 158 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.21263.20200813095708
86 158 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/iptbl_R0-0.log.21461.20200813095708
87 158 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/oom_R0-0.log.21266.20200813095708
88 1937 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/psvp_R0-0.log.19367.20200813095708
89 35874 Aug 13 2020 09:57:08 +00:00 /bootflash/tracelogs/reflector_9055_R0-0.log.10773.20200813095708
90 57099 Aug 13 2020 09:57:14 +00:00 /bootflash/tracelogs/inst_implode_dmesg.20200813095714
91 180 Aug 13 2020 10:00:04 +00:00 /bootflash/tracelogs/inst_issu_check_18287_R0-0.log.gz
92 180 Aug 13 2020 10:00:05 +00:00 /bootflash/tracelogs/inst_issu_check_18348_R0-0.log.gz
93 1275 Aug 13 2020 10:00:11 +00:00 /bootflash/tracelogs/cmand_R0-0.log.0000.20200813100011.gz
94 251 Aug 13 2020 09:59:53 +00:00 /bootflash/tracelogs/inst_compmatrix_R0-0.log.0000.20200813095953.gz
95 256 Aug 13 2020 10:00:11 +00:00 /bootflash/tracelogs/inst_rollback_timer_R0-0.log.0000.20200813100011.gz
96 387 Aug 13 2020 10:00:22 +00:00 /bootflash/tracelogs/cman_fp_F0-0.log.0000.20200813100022.gz
97 256 Aug 13 2020 10:00:22 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.0000.20200813100022.gz
98 256 Aug 13 2020 10:00:27 +00:00 /bootflash/tracelogs/btrace_rotate_sh_R0-0.log.0000.20200813100027.gz
99 170 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2113_R0-0.log.gz
100 172 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2112_R0-0.log.gz
101 170 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2111_R0-0.log.gz
102 170 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2110_R0-0.log.gz
103 170 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2109_R0-0.log.gz
104 171 Aug 13 2020 10:00:55 +00:00 /bootflash/tracelogs/cfgwr-2108_R0-0.log.gz
105 918 Aug 13 2020 10:05:22 +00:00 /bootflash/tracelogs/plogd_pmanlog_F0-0.log.gz
106 480 Aug 13 2020 10:05:27 +00:00 /bootflash/tracelogs/cmcc_0-0.log.0000.20200813100027.gz
107 908 Aug 13 2020 10:05:27 +00:00 /bootflash/tracelogs/plogd_pmanlog_0-0.log.gz
108 48163 Aug 14 2020 00:46:05 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200814004605.gz
109 47210 Aug 15 2020 06:19:31 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200815061931.gz
110 44775 Aug 15 2020 21:06:35 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200815210635.gz
111 45149 Aug 16 2020 11:51:50 +00:00 /bootflash/tracelogs/hman_R0-0.log.22715.20200816115150.gz
112 4096 Mar 19 2015 14:41:54 +00:00 /bootflash/.installer
113 423937288 Mar 19 2015 14:50:59 +00:00 /bootflash/isr4400-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin
1382912000 bytes available (5368991744 bytes used)
XX-R252#
But I still can't find any error or bug, After. I keep to console connect to this router and monitor.But I found this router auto reboot for two time after "INTERNAL ERROR".
*Aug 29 03:59:12.313: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 04:04:12.449: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 04:09:12.591: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 04:14:12.727: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 04:15:53.519: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR
*Aug 29 04:19:10.519: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR
*Aug 29 04:19:11.519: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR----------------------
Starting IOS XE kernel dump from previous failure.
Expected completion time is less than 5 minutes.
System will automatically reboot within 20 minutes.
------------reboot first time
Last reset cause: ResetRequest
Package Load Test Latency : 8954 msec
Image validated
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 12 seconds, expected max time 10 seconds
cisco Systems, Inc.
software.
export@cisco.com.
*Aug 29 04:32:08.117: pak_debug_init: Successfully initialized pak debug trace buffer
*Aug 29 04:32:15.810: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 29 04:32:17.518: adsl_ifmib_init
*Aug 29 04:32:17.592: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 29 04:32:17.592: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 29 04:32:17.592: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 29 04:32:17.592: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 29 04:32:19.809: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 29 04:32:19.860: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 29 04:32:19.861: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 29 04:32:19.861: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state t.o down
*Aug 29 04:32:19.861: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Aug 29 04:31:42.127: %CMRP-3-PFU_MISSING:cmand: The platform does not detect a power supply in slot 3
*Aug 29 04:31:56.518: %EVUTIL-6-PREREQUISITE:cmcc: Preferred library is absent
*Aug 29 04:32:03.699: %CMLIB-6-THROUGHPUT_VALUE:cmand: Throughput license found, throughput set to 500000 kbps
*Aug 29 04:32:04.535: %CPPHA-7-START:cpp_ha: CPP 0 preparing ucode
*Aug 29 04:32:04.559: %CPPHA-7-START:cpp_ha: CPP 0 startup init
*Aug 29 04:32:13.209: %CPPHA-7-START:cpp_ha: CPP 0 running init
*Aug 29 04:32:13.482: %CPPHA-7-READY:cpp_ha: CPP 0 loading and initialization complete
*Aug 29 04:32:13.603: %IOSXE-6-PLATFORM:cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Aug 29 04:32:22.841: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.10.125 port 0 CLI Request Triggered
*Aug 29 04:32:23.489: %LINK-5-CHANGED: Interface GigabitEthernet0/0/3, changed state to administratively down
*Aug 29 04:32:23.501: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 29 04:32:23.510: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 29 04:32:23.515: %SPA_OIR-6-OFFLINECARD: SPA (ISR4431-X-4x1GE) offline in subslot 0/0
*Aug 29 04:32:23.519: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 29 04:32:23.519: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 29 04:32:23.585: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 29 04:32:23.585: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 29 04:32:23.638: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 29 04:32:23.660: %SPA-3-ENVMON_NOT_MONITORED:iomd: Environmental monitoring is not enabled for ISR4431-X-4x1GE[0/0]
*Aug 29 04:32:23.705: %SYS-5-RESTART: System restarted --
*Aug 29 04:32:24.460: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.10.125 port 514 started - CLI initiated
*Aug 29 04:32:25.738: %SNMP-5-COLDSTART: SNMP agent on host XX-R252 is undergoing a cold start
*Aug 29 04:32:25.743: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/0
*Aug 29 04:32:25.774: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/1
*Aug 29 04:32:25.805: %TRANSCEIVER-6-INSERTED:iomd.: transceiver module inserted in Gigabitethernet0/0/2
*Aug 29 04:32:25.861: %SPA_OIR-6-ONLINECARD: SPA (ISR4431-X-4x1GE) online in subslot 0/0
*Aug 29 04:32:25.834: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/3
*Aug 29 04:32:27.749: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Aug 29 04:32:27.804: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Aug 29 04:32:27.806: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Aug 29 04:32:31.320: %TRANSCEIVER-3-INIT_FAILURE:iomd: Detected for transceiver module in Gigabitethernet0/0/3, module disabled
*Aug 29 04:32:34.420: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Aug 29 04:32:35.419: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Aug 29 04:32:40.199: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV...
*Aug 29 04:37:40.251: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 04:42:40.292: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 06:58:34.010: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR
*Aug 29 06:58:35.010: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR
*Aug 29 06:58:36.010: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERROR
*Aug 29 06:58:37.010: %IOSXE-4-PLATFORM:kernel: EDAC MC0: CE - no information available: INTERNAL ERR----------------------
------------reboot second time
Package Load Test Latency : 8947 msec
Image validated
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 13 seconds, expected max time 10 seconds
cisco Systems, Inc.
software.
export@cisco.com.
*Aug 29 07:10:32.499: pak_debug_init: Successfully initialized pak debug trace buffer
*Aug 29 07:10:40.134: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 29 07:10:41.948: adsl_ifmib_init
*Aug 29 07:10:42.023: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 29 07:10:42.024: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 29 07:10:42.024: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 29 07:10:42.024: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 29 07:10:44.234: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 29 07:10:44.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 29 07:10:44.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 29 07:10:44.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Aug 29 07:10:44.288: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed s.tate to up
*Aug 29 07:10:27.794: %CMLIB-6-THROUGHPUT_VALUE:cmand: Throughput license found, throughput set to 500000 kbps
*Aug 29 07:10:28.667: %CPPHA-7-START:cpp_ha: CPP 0 preparing ucode
*Aug 29 07:10:28.691: %CPPHA-7-START:cpp_ha: CPP 0 startup init
*Aug 29 07:10:37.361: %CPPHA-7-START:cpp_ha: CPP 0 running init
*Aug 29 07:10:37.633: %CPPHA-7-READY:cpp_ha: CPP 0 loading and initialization complete
*Aug 29 07:10:37.755: %IOSXE-6-PLATFORM:cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Aug 29 07:10:47.223: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.10.125 port 0 CLI Request Triggered
*Aug 29 07:10:47.822: %LINK-5-CHANGED: Interface GigabitEthernet0/0/3, changed state to administratively down
*Aug 29 07:10:47.882: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 29 07:10:47.892: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 29 07:10:47.897: %SPA_OIR-6-OFFLINECARD: SPA (ISR4431-X-4x1GE) offline in subslot 0/0
*Aug 29 07:10:47.900: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 29 07:10:47.900: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 29 07:10:47.934: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 29 07:10:47.934: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 29 07:10:47.938: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 29 07:10:47.963: %SPA-3-ENVMON_NOT_MONITORED:iomd: Environmental monitoring is not enabled for ISR4431-X-4x1GE[0/0]
*Aug 29 07:10:48.046: %SYS-5-RESTART: System restarted --
*Aug 29 07:10:48.823: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.10.125 port 514 started - CLI initiated
*Aug 29 07:10:50.104: %SNMP-5-COLDSTART: SNMP agent on host XX-R252 is undergoing a cold start
*Aug 29 07:10:50.574: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/0
*Aug 29 07:10:50.612: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/1
*Aug 29 07:10:50.643: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/2
*Aug 29 07:10:50.674: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/3
*Aug 29 07:10:50.682: %SPA_OIR-6-ONLINECARD: SPA (ISR4431-X-4x1GE) online in subslot 0/0
*Aug 29 07:10:52.625: %LINK-.3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Aug 29 07:10:52.628: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Aug 29 07:10:55.653: %TRANSCEIVER-3-INIT_FAILURE:iomd: Detected for transceiver module in Gigabitethernet0/0/3, module disabled
*Aug 29 07:10:56.032: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Aug 29 07:10:58.544: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Aug 29 07:10:59.544: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Aug 29 07:11:04.557: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV...
*Aug 29 07:16:04.604: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
*Aug 29 10:21:09.218: %ENVIRONMENTAL-6-NOTICE: V: PEM Out, Location: P0, State: Warning, Reading: 0 mV
Username: gxevc
Password:
XX-R252>en
Password:
XX-R252#show clock
*10:24:11.437 UTC Sat Aug 29 2020
XX-R252#dir
Directory of bootflash:/
11 drwx 16384 Mar 19 2015 14:40:10 +00:00 lost+found
16353 drwx 4096 Aug 29 2020 07:05:42 +00:00 core
359745 drwx 4096 Aug 13 2020 10:00:38 +00:00 .prst_sync
343393 drwx 4096 Mar 19 2015 14:41:36 +00:00 .rollback_timer
277985 drwx 36864 Aug 29 2020 07:15:21 +00:00 tracelogs
130817 drwx 4096 Mar 19 2015 14:41:54 +00:00 .installer
13 -rw- 423937288 Mar 19 2015 14:50:59 +00:00 isr4400-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin
7113240576 bytes total (3448119296 bytes free)
XX-R252#show mem sum
Processor 7F1D07C99010 1728098704 297992108 1430106596 679445864 1048575908
lsmpi_io 7F1D075971A8 6295128 6294304 824 824 412
Dynamic heap limit(MB) 1000 Use(MB) 0
XX-R252#show ver
software.
ROM: IOS-XE ROMMON
XX-R252 uptime is 3 hours, 14 minutes
Uptime for this control processor is 3 hours, 16 minutes
Last reload reason: <NULL>
export@cisco.com.
uc None None None
XX-R252#
XX-R252#dir
XX-R252#cd flash:core
XX-R252#dir
Directory of bootflash:/core/
16354 drwx 4096 Mar 19 2015 14:41:36 +00:00 modules
16355 -rw- 1436627610 Aug 29 2020 04:26:33 +00:00 kernel.rp_RP-ISR4400_0_20200829042633.core.gz
16356 -rw- 1438663388 Aug 29 2020 07:05:42 +00:00 kernel.rp_RP-ISR4400_0_20200829070542.core.gz
In the end, I copy the config from router to this website.
Command
show run
XX-R252>ena
Password:
XX-R252#ter le 0
XX-R252#show run
Building configuration...
Current configuration : 8622 bytes
! Last configuration change at 12:30:48 UTC Sat Aug 22 2020 by gavin
version 15.4
hostname XX-R252
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$Sp4E$tjBU2.xQVwGUcuHZMIKFq.
aaa new-model
aaa authentication login default group tacacs+ local
aaa session-id common
no ip domain lookup
ip domain name XX
login block-for 60 attempts 3 within 20
login on-failure log every 3
subscriber templating
license udi pid ISR4431/K9 sn FOC19059WYT
archive
path tftp://172.16.10.125/$h-config
write-memory
time-period 10080
username gxevc secret 5 $1$uvk6$pr5WVQImkvKTYhWTsMtvC0
redundancy
mode none
ip tftp source-interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/0
description connect-to-ISP
ip address 8.8.8.8 255.255.255.252
ip nat outside
media-type sfp
negotiation auto
interface GigabitEthernet0/0/1
description connect-to-WAN
ip address 9.9.9.9 255.255.255.224
ip nat outside
media-type sfp
negotiation auto
ip address 10.10.10.252 255.255.255.0
ip nat inside
media-type sfp
negotiation auto
vrrp 4 ip 10.10.10.254
vrrp 4 priority 201
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source list network interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 8.8.8.9
ip route 172.16.10.0 255.255.255.0 10.10.10.240
ip route 172.16.41.0 255.255.255.0 10.10.10.240
ip route 172.16.71.0 255.255.255.0 10.10.10.240
ip route 172.16.80.0 255.255.255.0 10.10.10.240
ip route 172.16.80.11 255.255.255.255 9.9.9.10
ip route 192.168.20.0 255.255.255.0 10.10.10.240
ip route 192.168.30.0 255.255.255.0 10.10.10.240
ip route 192.168.50.0 255.255.255.0 10.10.10.240
ip route 192.168.80.0 255.255.255.0 10.10.10.240
ip access-list standard network
permit 10.10.10.0 0.0.0.255
ip access-list standard ssh
permit 172.16.10.0 0.0.0.255
logging host 172.16.10.125
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps pfr
snmp-server enable traps flowmon
snmp-server enable traps ds1
snmp-server enable traps ds3
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps casa
snmp-server enable traps license
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dhcp
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps dsp video-usage
snmp-server enable traps dsp video-out-of-resource
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps ip local pool
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err binding-err conn-up conn-down binding-expn-fail oper-nodeid-change binding-conflict
snmp-server enable traps ethernet evc status create delete
snmp-server enable traps ether-oam
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps entity-state
snmp-server enable traps entity-qfp mem-res-thresh
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps flash insertion removal
snmp-server enable traps srp
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps cnpd
snmp-server enable traps mpls rfc ldp
snmp-server enable traps mpls ldp
snmp-server enable traps mpls rfc traffic-eng
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps bfd
snmp-server enable traps bgp cbgp2
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps pw vc
snmp-server enable traps ipsla
snmp-server enable traps sonet
snmp-server enable traps dlsw
snmp-server enable traps resource-policy
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps gdoi gm-start-registration
snmp-server enable traps gdoi gm-registration-complete
snmp-server enable traps gdoi gm-re-register
snmp-server enable traps gdoi gm-rekey-rcvd
snmp-server enable traps gdoi gm-rekey-fail
snmp-server enable traps gdoi ks-rekey-pushed
snmp-server enable traps gdoi gm-incomplete-cfg
snmp-server enable traps gdoi ks-no-rsa-keys
snmp-server enable traps gdoi ks-new-registration
snmp-server enable traps gdoi ks-reg-complete
snmp-server enable traps firewall serverstatus
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps alarms informational
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps rf
snmp-server enable traps transceiver all
snmp-server enable traps mpls vpn
snmp-server enable traps mpls rfc vpn
snmp-server host 10.10.10.179 version 2c public
snmp-server host 10.10.10.181 version 2c public
snmp-server host 10.10.10.39 version 2c public
tacacs server gxevc
address ipv4 172.16.10.125
key gxevc
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class ssh in
exec-timeout 5 0
transport input ssh
end
Final, I was fined $100 by the company. I this this hardware's problem. Why I was fined $100. I can't accept the fact.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
