Javanshir
Hi after upgrade cisco ios when booting system it stuck %INIT: waited 0 seconds for NVRAM to be available
I try to get rommon mode but can't
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
Last reset at: Tue Nov 01 22:27:19 UTC 2022
ASR1002-RP1 platform with 4194303 Kbytes of main memory
Warning: filesystem is not clean
Located asr1000rp1-adventerprisek9.03.16.10.S.155-3.S10-ext.bin
Image size 395094652 inode num 12, bks cnt 96459 blk size 8*512
Boot image size = 395094652 (0x178caa7c) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAY
Using midplane macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated d1436b43:6b2d43f9:4ab242e9:5bdc6e1e:0d6c0173
expected d1436b43:6b2d43f9:4ab242e9:5bdc6e1e:0d6c0173
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): tdl_boot_time_resolve took: 107 seconds, expected max time 30 seconds
Nov 1 22:32:22.209 R0/0: %PMAN-3-PROC_EMPTY_EXEC_FILE: Empty executable used for process vman
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ASR1000 Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.5(3)S10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 19-Sep-19 10:50 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor (revision 2RU) with 1638757K/6147K bytes of memory.
Processor board ID FOX1535GV1Q
14 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
7816672K bytes of USB flash at usb0:.
It is like this
4 Comments
