pardeepk
Frequent Visitor
Frequent Visitor
Eap- TLS is a sort of EAP method to authenticate client with the certificate without use of usern-ame an password.
Below example is to use EAP-TLS with controller
EAP-TLS requires digitally signed certificate to authenticate clients. Certificate required on controller. 1. Device Certificate issue to WLC. To generate the device certificate. http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html And download it to the controller it is vendor device certificate using command line or GUI.In GUI select the download vendor device certificate option (TACLAB)transfer download mode tftp (TACLAB) >transfer download datatype eapdevcert (TACLAB) >transfer download path . (TACLAB) >transfer download filename final.pem (TACLAB) >transfer download certpassword check123 (TACLAB) >transfer download serverip 192.168.178.52 (TACLAB) >transfer download start 2. Root Certificate of a CA. If you have root ca certificate on device ,you can export it using the Firefox. Path- browser>>Advance>>Encryption>>view certificate>>Export.>>>save it as x.509 file type certificate. E.g-test.crt And download it the controller.It is ca certificate.In GUI select the (TACLAB)transfer download mode tftp (TACLAB) >transfer download datatype eapdevcert (TACLAB) >transfer download path . (TACLAB) >transfer download filename final.pem (TACLAB) >transfer download certpassword check123 (TACLAB) >transfer download serverip 192.168.178.52 (TACLAB) >transfer download start . Root-CA certificate should be installed on controller as well as clients. Now configure a profile with EAP-TLS on controller and inherit it to the SSID under advanced section To configure local eap profile below is the document. https://mrncciew.com/2013/04/21/configuring-local-eap-on-wlc/.
