fsebera
Level 4
Level 4
Hello!
I'm looking for a way to make my EEM script more dynamic and automated for my environment.  This is what I have - basically I just capture the 4 IPSec peer IP addresses of each neighbor and insert this data into 4 different variables.
cli command "show crypto session | i port"
string range "$_cli_result" 6 20
regexp "[0-9]+" "$_string_result" IP1
string range "$_cli_result" 24 60
regexp "[0-9]+" "$_string_result" IP2
puts "IP1=$IP1"
puts "IP2=$IP2"
etc.
etc.
etc.
Script output:
IP1=10.0.3.1
IP2=10.0.2.1
IP3=20.0.3.1
IP4=20.0.2.1
My configuration is manually set for the 4 neighbors I currently have setup and I guesstimate the IP address space required (Eg. 192.168.100.111 verses  10.0.1.1).  If the IP address is not 3 full values per octet, some strings could be off.
Also, I would like to cycle through the   "show crypto session | i port"   cli command output and dynamically figure out how many neighbors I have instead of my current manual method of hard setting this configuration in the script.
ANY HELP would be greatly appreciated.
Thank you
Frank
