ShaunGreen
Dear All,
I'd like to run the following past you to see if anyone is able to shed more light on the subject.
We've noticed that when a show running-config is issued against a non L type 9300 (although it's running 16.9.5) the ACL's are in an output format that I would normally expect, I.e.
Name of ACL and then then the permit/deny rules (but no line numbering).
When the same command (show running-config) is issued against a 9300 L model (running 16.12.4) the output has the line numbers to each rule.
I would expect this if a show ip access-list command was run, but not with show running-config.
Is anyone able to share any more information on why there is a difference?
Is there anyway to configure the L model to display the output without the line numbering?
Simon.
2 Comments
