szeya
Hosting Native Docker Container on C9300
Powered by an x86 CPU, the application hosting solution on the Cisco® Catalyst® 9000 series switches provide the intelligence required at the edge. This gives administrators a platform for leveraging their own tools and utilities, such as a security agent, Internet of Things (IoT) sensor, and traffic monitoring agent.
Application hosting on Cisco Catalyst 9000 family switches opens up new opportunities for innovation by converging network connectivity with a distributed application runtime environment, including hosting applications developed by partners and developers.
Cisco IOS XE 16.12.1 introduced native Docker container support on Catalyst 9300 series switches. Now, C9404 and C9407 models also can support Docker container with Cisco IOS XE 17.1.1 release.  This enables users to build and bring their own applications without additional packaging. Developers don’t have to reinvent the wheel by rewriting the applications every time there is an infrastructure change. Once packaged within Docker, the applications will work within any infrastructure that supports docker containers.
In this blog, you will see how you can use native docker image (iperf) from Docker Hub to measure network performance by hosting on Cisco Catalyst 9300 switch.
Step-by-step installation configuration
1. Download the iPerf docker image to the local laptop.
Download the latest iPerf image from Docker Hub to the laptop.
Docker engine has to be installed on laptop and can pull iPerf image from Docker Hub.
MyPC$ docker pull mlabbe/iperf3
Save the downloaded iPerf docker image as a tar archive:
MyPC$ docker save mlabbe/iperf3 > iPerf.tar
2. Login to the Catalyst 9300 and copy the iPerf.tar archive to the flash: drive.
copy usbflash0:iPerf.tar flash:
3. Configure network connectivity to the IPerf docker.
a. Create the VLAN and VLAN interface:
      conf t
      interface Vlan123
b. Configure the AppGigabitEthernet1/0/1 interface:
       interface AppGigabitEthernet1/0/1
       switchport mode trunk
The above configuration allows VLAN 123 on the AppGigabitEthernet port.
c. Map vNIC interface eth0 of the IPerf docker to VLAN 123 on the AppGigabitEthernet 1/0/1 interface:
       conf t
       app-hosting appid iPerf
       app-vnic AppGigEthernet trunk
       guest-interface 0
       vlan 123 guest-interface 0
       guest-ipaddress 172.26.123.202 netmask 255.255.255.0
       app-default-gateway 172.26.123.1 guest-interface 0
4. Enable and verify App Hosting.
a. Verify that the USB SSD-120G flash storage is used.
     dir usbflash1:
     Directory of usbflash1:/
    11 drwx           16384    Mar 25 2019 22:32:36 +00:00    lost+found
    118014062592 bytes total (105824313344 bytes free)
Note: SSD-120G will be shown as usbflash1: in IOS-XE CLI. Internal flash and front panel usb (usbflash0:) do not support for application hosting.
b. Configure iox for App Hosting:
 conf t
 iox
show iox-service
IOx Infrastructure Summary:
 IOx service (CAF)      : Running
 IOx service (HA)        : Running
 IOx service (IOxman)  : Running
 Libvirtd                      : Running
 Dockerd                    : Running
5. Install ,activate and run the IPerf docker cat9k application.
a. Deploy the IPerf docker application:
   app-hosting install appid iPerf package flash:iPerf.tar
   Installing package 'flash:iPerf.tar' for iPerf. Use 'show app-hosting list' for progress.
    App id                                   State
    iPerf                                  DEPLOYED
 b. Activate the IPerf docker application:
    app-hosting activate appid iPerf
    iPerf activated successfully
    Current state is: ACTIVATED
c. Start the IPerf docker  application:
    app-hosting start appid iPerf
    iPerf started successfully
    Current state is: RUNNING
d. Verify that the IPerf docker  application is running:
    App id                                   State
     iPerf                                  RUNNING
6. Working with the app.
a. Check app details.
   show app-hosting detail appid iperf
   App id                 : iperf
   Owner                 : iox
   State                   : RUNNING
   Application
   Type                    : docker
   Version                : latest
   Description          :
   Path                 : usbflash0:iperf3_sai.tar
   Activated profile name : custom
   Resource reservation
     Memory              : 2048 MB
     Disk                    : 4000 MB
     CPU                    : 7400 units
     VCPU                  : 1 units
   Attached devices
     Type              Name               Alias
     serial/shell      iox_console_shell   serial0
     serial/aux        iox_console_aux     serial1
     serial/syslog    iox_syslog          serial2
     serial/trace      iox_trace           serial3
   Network interfaces
  eth0:
   MAC address        : 52:54:dd:50:b5:ce
   IPv4 address         : 172.26.123.202
   Network name      : mgmt-bridge193
   Docker
   Run-time information
     Command              :
     Entry-point             : iperf3 -s
     Run options in use  :
   Application health information
     Status                    : 0
     Last probe error     :
     Last probe output   :
b. Check app utilization.
   show app-hosting utilization appid iPerf
   Application: iPerf
   CPU Utilization:
     CPU Allocation: 7400 units
     CPU Used: 1.49 %
   Memory Utilization:
     Memory Allocation: 2048 MB
     Memory Used: 893 KB
  Disk Utilization:
     Disk Allocation: 4000 MB
     Disk Used: 0.00 MB
7. Monitoring performance between the laptop and C9300.
MyPC$ iperf3 -c 172.26.123.202
Connecting to host 172.26.123.202, port 5201
[  5] local 10.154.164.97 port 59408 connected to 172.26.123.202 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  7.51 MBytes  63.0 Mbits/sec
[  5]   1.00-2.00   sec  8.24 MBytes  69.2 Mbits/sec
[  5]   2.00-3.00   sec  10.0 MBytes  84.2 Mbits/sec
[  5]   3.00-4.00   sec  9.52 MBytes  79.9 Mbits/sec
[  5]   4.00-5.00   sec  9.36 MBytes  78.5 Mbits/sec
[  5]   5.00-6.00   sec  10.8 MBytes  90.8 Mbits/sec
[  5]   6.00-7.00   sec  10.1 MBytes  84.9 Mbits/sec
[  5]   7.00-8.00   sec  9.62 MBytes  80.7 Mbits/sec
[  5]   8.00-9.00   sec  10.9 MBytes  91.2 Mbits/sec
[  5]   9.00-10.00  sec  4.51 MBytes  37.7 Mbits/sec
[  5]   0.00-10.00  sec  90.6 MBytes  76.0 Mbits/sec                  sender
[  5]   0.00-10.01  sec  90.1 MBytes  75.5 Mbits/sec                  receiver
21 Comments
