stelliot
A friend of mine recently asked me to assist them with configuring a Cisco ISR router for BT Infinity / Fibre. I decided to share the configuration for others to leverage.
Please note this configuration is far from complete and represents a real bare bones configuration without additional security and device hardening present. It is not in anyway a recommended configuration but can be used as a test / baseline.
Router: 2900 (2911)
IOS: 15.1(4)M4
ADSL  card:
NAME: "ADSL/VDSL over POTS supporting ADSL1, ADSL2, ADSL2+ and VDSL2 on Slot 0 SubSlot 1", DESCR: "ADSL/VDSL over POTS supporting ADSL1, ADSL2, ADSL2+ and VDSL2"
PID: EHWIC-VA-DSL-A
Running configuration, with usernames / passwords omitted:
Building configuration...
Current configuration : 2979 bytes
version 15.1
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp pool DHCP Pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
 dns-server 62.6.40.178 8.8.8.8
 lease 30
no ip domain lookup
redundancy
controller VDSL 0/1/0
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/1/0
no ip address
interface Ethernet0/1/0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer-group 1
keepalive 30
ppp authentication pap chap ms-chap callin
ppp chap hostname XXXXX@XXXXX
ppp chap password 7 XXXXXXXX
ppp pap sent-username XXXX@XXXX password 7 XXXXXXXXXX
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 remark Internet access
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
exec-timeout 5 0
password 7 <removed>
logging synchronous
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
end
