sudsaman
In enterprise networks, standard and extended ACLs (Access Control Lists) are used to provide traffic filtering capabilities to protect the network from unwanted access and other spoofing attacks. The biggest limitation of traditional access control lists is their stateless nature. They do not keep track of the state of a connection; therefore, if someone inside the network sends traffic to the Internet, it is hard to safely allow the returning traffic back into your network without opening a large hole in your network with ACL configurations. Traditional ACLs consume a lot of TCAM (Ternary Content Addressable Memory) memory since there are multiple static inbound and outbound flow combinations with multiple match criteria that must be met to allow traffic in and out of the network. To provide a stateful behavior to the Access List, Cisco has introduced the Reflexive ACL feature on Catalyst 9000 series switches starting from IOS-XE 17.10.1 release.
Access List
Let us look at the network topology above. Consider that there are two networks, the Internal network (192.168.10.0) and the External network (192.168.20.0). Let us consider a scenario, where an internal host wants to access an external server and a host wants web access to the server.
In using an extended access list, we would have to configure ACLs on the inbound interface on the border switch to allow the “web” traffic from the server to the host in the internal network.
Switch#conf t
ip access-list extended ACL_inbound
permit tcp host 192.168.10.170 host 192.168.20.115 eq  www
deny ip any any
end
Switch#conf t
interface GigabitEthernet1/0/4
no switchport
ip address 192.168.10.11 255.255.255.0
end
Switch#conf t
int gi1/0/22
no switchport
ip address 192.168.20.21 255.255.255.0
ip access-group ACL_inbound in
end
The above configured ACL being applied to one host in the network seems fine. But one thing to consider, it will not be possible on a large-scale network, to access the Web server or simple ping, you must allow all WWW/ICMP replies to return to these devices or different services. These all-filter statements are always active, so the hacker could implement a denial of service (DoS) spoofing attack against the network. You must include them in the extended ACL, which easily increases the TCAM memory available to the switch.
Reflexive Access List
What the reflexive ACL does differently is that it provides a form of bi-directional filtering, allowing the returning traffic of these connections that originated from inside the network back in. Reflective ACLs will deny the traffic that originates outside of your network and attempts to connect to internal resources.
Whenever an internal device opens a session to the outside world, this temporary entry allows the returning traffic for this session back through the border switch which will create temporary entries in your inbound filter.
Reflexive ACL Configuration as an example:
!Configure reflexive access list on outbound interface!
Switch#conf t
ip access-list extended ACL_out
permit tcp host 192.168.10.170 host 192.168.20.115 eq www reflect R1 timeout 100
!where R1 is the name of the reflexive access list!
!timeout of 100 is to put a timer on the temporary entries created!
deny ip any any
end
Switch#conf t
int g1/0/4
ip access-group ACL_out in
end
!Configure reflexive access list on inbound interface!
Switch#conf t
evaluate R1
deny ip any any
end
Switch#conf t
int g1/0/22
ip access-group ACL_in in
end
ACL with "reflect" ACL will create temporary entries that will permit the reverse traffic. This entry will be hit only if there is an ACL with an "evaluate" ACL in the reverse direction applied.
Reflexive ACL provides numerous advantages to the enterprise network, including stateful filtering, which is much harder to spoof because more filter criteria must be matched before a packet is permitted, and uses temporary filters which are removed when a session is over. This limits the hacker's attack opportunity to a smaller time window.
There are more benefits to using Reflexive Access-Lists. Such as the ability to effortlessly implement and configure, while stipulating greater control over external traffic because of its stateful nature. It will work on all the Catalyst 9000 switches where you must install IOS-XE 17.10.1 (and onwards).
2 Comments
