I want to read static route and default route configuration via SNMP ,like the show run command output below.
IP route 10.0.0.0 255.0.0.0 60.1.1.1
IP route 0.0.0.0 0.0.0.0 60.1.1.2
The IP MIB - IPForward-ipcidrRoute table shows the routes if only when the interface which has static route configuration, is up. I want to read the IP route configuration even all the interfaces is down.
Thank you
