Anand G
Works on 29xx, 37xx, 45xx & 65xx series model switches
Checking the Cable Status Using the TDR
You can check the status of copper cables using the time domain reflectometer (TDR). The TDR detects a cable fault by sending a signal through the cable and reading the signal that is reflected back to it. All or part of the signal can be reflected back by any number of cable defects or by the end of the cable itself.
Use the TDR to determine if the cabling is at fault if you cannot establish a link. This test is especially important when replacing an existing router, upgrading to Gigabit Ethernet, or installing new cables.
The port must be up before running the TDR test. If the port is down, you cannot enter the test cable-diagnostics tdr command successfully, and the following message is displayed:
router#test cable-diagnos tdr int gig0/1
% Interface Gi0/1 is administratively down
% Use 'no shutdown' to enable interface before TDR test start.
Note: TDR can test cables up to a maximum length of 115 meters.
How to run the test?
router # test cable-diagnos tdr int gig0/1
TDR test started on interface Gi0/1
A TDR test can take a few seconds to run on an interface
To Check the Result:
'show cable-diagnostics tdr int gig0/1' will provide the TDR results.
A Sample Run Result:
switch#sh ip int bri | i up
GigabitEthernet0/1     unassigned      YES unset  up                    up
switch#
switch#test cable-diagnostics tdr interface gigabitEthernet 0/1
Use 'show cable-diagnostics tdr' to read the TDR results.
switch#
*Mar  1 01:59:05.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Mar  1 01:59:06.238: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Mar  1 01:59:12.772: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Mar  1 01:59:13.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
switch#
Output:
switch#show cable-diagnostics tdr interface gigabitEthernet 0/1
TDR test last run on: March 01 01:59:04
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/1     1000M Pair A     8    +/- 10 meters Pair B      Normal
                        Pair B     8    +/- 10 meters Pair A      Normal
                        Pair C     8    +/- 10 meters Pair D      Normal
                        Pair D     8    +/- 10 meters Pair C      Normal
switch#
Anand G
3 Comments
Jose Solano
Level 4
Level 4
Nice to know this test is available I think it can be really helpful..!
Anand G
Thanks Jose for your comments !
Though it is a basic test, it would be helpful in identifying and narrow down the L1 issue.
Leo Laohoo
Even though TDR is supported on the 3560G/E/X, 4500 and/or 6500 chassis, I wouldn't recommend it.  Two main reasons:
1.  TDR on the line card of the 4500 and/or 6500 (regardless of model and supervisor card) takes approximately 61 seconds (versus five to seven seconds on Catalyst 2960/G/X/R and Calatyst 3750G/E/X); and
2.  TDR results on the 4500 and/or 6500 are, for a lack of a better word, "LACKING".  TDR functions on these two platform is NOT design to do anything.  The results won't give you what fault, how far is the fault, and which pins are faulty.  The TDR result will only tell you if there's a fault or not.  PER to our Cisco SE/AM have proven to be useless.  Privately, I was told that the DEV of both BU "doesn't care" and "don't have the time" to improve TDR functionality.
My document on TDR:  http://supportforums.cisco.com/document/74231/how-use-time-domain-reflectometer-tdr
