Hi I'm setting up a policy map on a Cisco 3850 switch. But having trouble matching an interface. On the 3750 model you could match traffic on an input interface: Class-map match-all Example match input-interface G1/0/10 - G1/0/11 ...
view more
I've 2 x sg350x-12pmv switches i'm configuring for a datacentre.They are fully configured and workingProblem is i've configured the management vlan on ports 1 and 11If i boot the switch and it comes online, port 11 will not work with a direct cable for ac...
view more
Hi I am trying to set up a new vpc between a pair of nexus 93180 and nexus 3172I was planning to set it up as trunk with no vlans allowed (switchport trunk allowed vlan none) so that I can add vlans once the port channel is up, however it bounces up and d...
view more
