Introduction
This document contains Frequently Asked Questions(FAQ's) about Internet  Protocol Version 6(IPv6).
Q. How to limit clients getting an  IPv6 address without using a DHCP server ?
A. Use the command"ipv6nd prefix <prefix> no-advertise".This will set a bit in theIPv6 NA packets to tell hosts not to use this prefix for  autoconfiguration.
Q. When configuring  Dual Stack VRF,IPv6 address family is not listed as shown in the  example
Ex:  Router(Config-vrf)#address-family
      ipv4  Address  family
      Router(config)#interface  GigabitEthernet0/0.901
      Router(config-subif)#ipv6 en
       Router(config-subif)#ipv6 enable
      %GigabitEthernet0/0.901 is  linked to a VRF. Enable IPv6 on thatVRF first.
A. In ""show version"",  check if  the Data license is activated.
Router#  show  version
Technology  Package License Information for Module:'c2900'
Technology
Technology-package
Technology-package
Technology-package
 CurrentTypeNext   reboot
ipbase
ipbasek9permanentipbasek9
securityNoneNoneNone
uc
NoneNoneNone
data
NoneNoneNone
Activate the data   license then check, the IPv6 address family will be enabled
Router(config-vrf)#address-family   ?
   ipv4  Address family
   ipv6  Address family
Q. What is the  equivalent command in IPv6 to the "ip igmp helper-address"command?
A. The command is "ipv6 mld host-proxy".MLD proxy feature works in 15.1.2T  or later IOS release.
Q. Why Windows  2003 machine not getting IPv6 address from a DHCP server configured on  Cisco 1800 series router?
A. Windows XP and Windows Server 2003 do not support DHCPv6-based IPv6  address configuration. For further information
refer http://technet.microsoft.com/en-us/library/bb726956.aspx
Q. In a dual  stack network, does the HSRP configuration for an existing interface use  the same group ID as the IPv4 group?
A. HSRP for IPv4 and IPv6 do not have the same group number. One can use  any valid group number for either protocol
Q. Is MHSRP supported on IPv6?
A. Yes,here is a sample IPv6 MHSRP (Multi HSRP)  configuration.
Rtr1  Configuration
interface Vlan10
ipv6 address  2620:A3::188/64
standby 100 ipv6 FE80:2620:A3::189
standby 100  timers 1 4
standby 100 priority 101
standby 101 ipv6  FE80:2620:A3::190
standby 101 timers 1 4
standby 101 priority 200
standby  101 preempt
Rtr2 Configuration
interface  Vlan10
ipv6 address 2620:A3::187/64
standby 100 priority 200
standby  100 preempt
standby 101 priority 101
On Router 1
Router1#show standby brief
                      P indicates configured to preempt.
Interface    Grp  Pri P State   Active          Standby         Virtual IP
Vl10         100  101   Standby FE80::5675:D0FF:FE39:F77F
                                                local           FE80:2620:A3::189
For IPv6 HSRP Configuration example, refer document "IPv6 HSRP Configuration Example"
Q. What's the recommended method to  inform IPv6 clients about a dhcpv6 server?
A. The command that enables IPv6 Relay Agent on an interface:ipv6 dhcp  relay destination <IPv6 address>
For more information on this  command refer :http://www.cisco.com/en/US/partner/docs/ios/ipv6/configuration/guide/ip6-dhcp.html#wp1054443
Q. Getting  Error Message when creating address-family for IPv6 on the 7600 as shown  in the example:
Example : Router(config-vrf)#address-family ipv6
% VRF address family  ipv6 is not supported or not enabled
% Can't activate address-family  'ipv6'
A. In order to enable IPv6 in a VRF, enter the ""mls ipv6 vrf"" command  in global configuration mode. If this command is not used, a VRF is  supported only for the IPv4 address family. Example: Router(config)# mls  ipv6 vrf.For further information on this command refer:
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_09.html#wp2335362
Q. Can I use  two different BGP public AS's like 13445 and 109, one for IPv4 and one  for IPv6.
A. No, for ASes one can only configure one  BGP instance(AS) per box. This is a restriction of both IPv4 and IPv6.
Q. What is the  different between IPv6 Multicast Address and Anycast Address ?
A. Both Multicast address and Anycast  Address identifies a group of nodes or interfaces.Traffic destined for a  multicast address is forwarded to
all the nodes in the group where as  the traffic destined to an anycast address is forwarded to the nearest  node in the group. An anycast address
is essentially a unicast address assigned to more than one interface. For example to identify the set of routers attached    to a particular subnet,
Subnet-Router anycast address is used. The Subnet-Router anycast address is represented by which has a host ID of 0  (0000:0000:0000:0000)
and "subnet prefix" in an anycast address is the prefix that    identifies a specific link.
Q. Does a 7206VXR router support IPV6 Dual Stack Implementation?
A. Yes. It is supported.
Q. On configuring an IPv6 HSRP standby group, run into an error message: "%FHRP group not consistent with already configured groups on the switch stack."
A. Only HSRP version 2 supports both IPv4 and IPv6. So configure "standby version 2" under interface.
Q. Error message: "% BGP context not been initialized properly." when Configuring neighbor under address-family IPv6
A. The issue is with the feature set. If the feature set is SP services, the following services are not supported.
  • IPv6 Routing: Multiprotocol BGP Extensions for IPv6
  • IPv6 Routing: Multiprotocol BGP Link-local Address Peering
To use these features,change the feature set to Advanced Enterprise Services.
Q. How to configure IPv6 netflow?
A. Configuring IPv6 netflow means configuring collection of hardware-routed IPv6 flows. IPv6 netflow is independent of IPv4 netflow except for export configuration, which is same for both. For commands and configuration example, check: How to configure Netflow v9 for IPv6
Q. When configuring IPv6 Netflow on Catalyst 6500 at the interface level,there is no ability to specify the direction of flow export !
A. 6500 platform cannot support egress netflow due to platform limitation, only ingress is supported.For more information, check NDE Configuration Guidelines and Restrictions.
Q.How to configure ICMP rate limiting in an IPv6 environment?
A. ICMP rate limiting is enabled by default with a default interval between error messages of 100 milliseconds and a bucket size (maximum number of tokens to be stored in a bucket) of 10. The command is "ipv6 icmp error-interval". This can be checked by giving "show ip interface <Interface Type> and the output is shown as below:
For further information refer http://www.cisco.com/en/US/docs/switches/lan/catalyst2350/software/12.2_46_ey/configuration/guide/swipv6.html#wp1117074
Q. How is summarization done for IPV6 OSPF?
A. The command for IPv6 summarization is summary-prefix.
In the following example, the summary prefix FEC0::/24 includes addresses FEC0::/1 through FEC0::/24. Only the address FEC0::/24 is advertised in an external link-state advertisement.
ipv6 router ospf 1
router-id 172.16.3.3
summary-prefix FEC0::/24
redistribute static
Native ospf (non-external) routes are summarized using the Area range command. For more information refer to
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_01.html#wp2113662
The following example specifies one summary route to be advertised by the ABR to other areas for all subnets on network 10.0.0.0 and for all hosts on network 192.168.110.0:
interface Ethernet0/0
no ip address
ipv6 enable
ipv6 ospf 1 area 1
ipv6 router ospf 1
router-id 192.168.255.6
log-adjacency-changes
area 1 range 2001:1DB8:0:1::/64
Q.How to configure IPv6 under vrf  as we need to activate bgp?
A. Here is a configuration guide for Multiprotocol VRF Configuration.
http://www.cisco.com/en/US/docs/ios/ios_xe/mpls/configuration/guide/mp_vpn_ipv4_ipv6_xe.html#wp1055416
Q.On a 3750 Catalyst switch, IPv6 ping doesn't work when "switchport block multicast" is configured.
A. Change the sdm template on switch to "dual-ipv4-and-ipv6 routing". To check the current sdm template, use the command show sdm prefer
To change the sdm template, in the config mode use the command sdm prefer dual-ipv4-and-ipv6 routing.
Note that changing the sdm template requires a reload.
Example:
Switch_3750(Config)# sdm prefer dual-ipv4-and-ipv6 routing
Switch_3750(Config)# exit
Switch_3750# reload
For more information on configuring the sdm templates refer Configuring SDM Templates
Q.Is IPv6 NAT-PT supported by IPv6 cef?
A. NAT-PT is not supported in IPv6 cef path, disable IPv6 cef for NAT-PT. Other option is to go for NAT64, which is available in ASRs currently.
Q.Error message: "% VRF address-family IPv6 is not supported or not enabled" is received when configuring IPv6 address-family within a VRF?
A. Configure the command "mls ipv6 vrf" in the global configuration mode in order to enable IPv6 in VRF.
Q.Can I configure a vlan for IPv6?  How do I go about doing this?
A. To configure a vlan for IPv6, you can change your /48 into /64s (per RFC). /64 can be configured on the  SVI by doing the following steps:
1.) Enable IPv6 Unicast routing
"ipv6 unicast-routing"
2.) Enable IPv6 CEF
"ipv6 cef"
3.) Configure the IPv6 address
  interface vlan 100
   ipv6 address 2620:0046::1/64
Q.When peering with eBGP peer using link local IPv6 address an error message is followed:
% BGP(v6): Invalid scope. Unable to configure link-local peer.
Router(config-router)#neighbor FE80::222:83FF:FEDF:5852%te2/2 remote-as 65222
A. The correct syntax for establishing BGP session with link-local IPv6 address is as follows:
neighbor link-local-address%interface-name remote-as #
Please note that the %interface-name must be the complete interface name:
Router(config-router)#neighbor FE80::A8BB:CCFF:FE00:C800%Ethernet0/0 remote-as 1
Q.Do you have a chart or documentation on the compatibility of routing protocols, including IPv4 and IPv6, running in the same router?
A. IPv6 and IPv4 routing protocols do co-exist on the same device and there is no compatibility issues between two.
Q.Not able to enable IPv6 addressing scheme on a port-channel interface.
Example:
Router(config)#int port-channel 1
Router(config-if)#ipv6 ?
% Unrecognized command
% Invalid input detected at '^' marker.
A. IPv6 Addresses on a port-channel are unsupported at this time.
Q.Does the Catalyst 3560/3750 supports IPv6 policy based routing (PBR)?
A. Catalyst 3560/3750 does not supports IPv6 policy based routing (PBR). For more details please refer to Unsupported IPv6 Unicast Routing Features on Catalyst 3750 guidelines.
Q. What are major differences between IPv4 and IPv6?
A. A detailed journal is available; please read IPv6 Internal.
Q. What is the default route in IPv6.
A. The default route (any) in IPv6 is specified by ::/0. For example, route to any network in IPv6 (static) will be configured as
Router(config)# ipv6 route ::/0 serial 1/0
Q. Does ASR1K supports tunnel mode gre IPv6?
A. As of now the feature is not available on ASR1K platform. For complete configuration refer to Implementing Tunnels.
Q. Is GLBP for IPv6 supported on 3560E?
A. No, please see Configuring IPv6 Unicast Routing section of configuration for 3560E switches.
Q. What is the feature on IPv6 on Catalyst 6500 similar to ip-helper address?
A. A DHCP relay agent, which may reside on the client's link, is used to relay messages between the client and server. DHCP relay agent operation is transparent to the client. A client locates a DHCP server using a reserved, link-scoped multicast address. Therefore, it is a requirement for direct communication between the client and the server that the client and the server be attached to the same link. However, in some situations in which ease of management, economy, or scalability is a concern, it is desirable to allow a DHCP client to send a message to a DHCP server that is not connected to the same link.
Perform this task to enable the DHCPv6 relay agent function and specify relay destination addresses on an interface.
SUMMARY STEPS
1. enable
2. configure terminal
3. interface type number
4. ipv6 dhcp relay destination ipv6-address [interface-type interface-number]
For a detailed information on when and where to configure the above command, please click on the following link: Implementing DHCP For IPv6
Q. How to find the IPv6 address assigned to a host via DHCP over VPDN?
A. Use command "show ipv6 int virtual-access 2.1 prefix".
For example,
Router# show ipv6 int virtual-access 2.1 prefix
IPv6 Prefix Advertisements Virtual-Access2.1
Codes for 1st column:
        A - Address, P - Prefix-Advertisement, O - Pool
        U - Per-user prefix
Codes for 2nd column and above:
        D - Default
        N - Not advertised, C - Calendar
PD default [LA] Valid lifetime 2592000, preferred lifetime 604800
OD 2404:B800:AD32::/64 [LA] Valid lifetime 2592000, preferred lifetime
604800
Q. IPv6 VRF support is available from which IOS release?
A. The feature is available on IOS XE 3.1.0S onwards on ASR 1000 platform.
Also, check Cisco Feature Navigator for further validation (Requires user id and password).
Q. What is the command that can be used to re-sequence IPv6 access control list (ACL)?
A. IPv6 acl re-sequence feature is not available in IOS.
Q. What are the ICMPv6 messages used by the neighbor discovery protocol?
A. There are 5 ICMPv6 messages used by the neighbor discovery protocol. They are listed as below:
  • Router Solicitation (RS)
  • Router Advertisement (RA)
  • Neighbor Solicitation (NS)
  • Neighbor Advertisement (NA)
  • Redirect
Q. IPv4 to IPv6. What happened to IPv5?
A. According to Wikipedia, Internet Protocol Version 5 was used by the Internet Stream Protocol, an experimental streaming protocol.  The second version (of Internet Stream Protocol), known variously as ST-II or ST2, distinguishes its own packets with an Internet Protocol version number 5, although it was never known as IPv5.  The Internet Stream Protocol family was never introduced for public use, but many of the concepts available in ST are similar to later Asynchronous Transfer Mode protocols and can be found in Multiprotocol Label Switching (MPLS). They also presaged Voice over IP.   Since the number 5 was already allocated, this number was not considered for the successor to IPv4. Several proposals were suggested as the IPv4 successor, and each was assigned a number. In the end, it happened that the one with version number 6 was selected.
Q. Not able to configure IPv6 on a WS-SUP32-GE-3B with IP Services Cisco IOS. Does Sup32 supports IPv6?
Switch(config)#ipv6?
A. Sup32 does support IPv6 but on 12.2(33) SXI or later then you can use IP services.
Q. Does the Cisco IPSec VPN Client support IPv6 ?
A.The IPSEC client can only form tunnels between IPv4 endpoints, and will only transport IPv4 packets inside the tunnel.If  you are using something
that will tunnel IPv6 inside IPv4 (ISATAP,6in4),the IPv6 will be transported but only because it looks like an  IPv4 packet at the driver layer.
The classic Cisco VPN client only carries IPv6 over IPSEC if the IPv6 is tunneled inside IPv4.For native IPv6 transport, you can use
Cisco AnyConnect VPN client.
Q. What is the reason for a dedicated link local address for each VLAN?
A. One of the advantages of IPv6 is the fact that every link has a link  local addresses that are significant only for that link, in addition to  having at least one global address.  The fact that the same link-local  address can appear on multiple different links should be embraced as a  benefit.
The  ability to have many different addresses on an interface is one of the  useful traits of IPv6 that can provide an advantage over IPv4
Related Information
Janel Kratky
Another good resource for related information is the IPv6 Knowledge Base Portal.
jsmall123
"An anycast address is essentially a unicast address assigned to multiple devices with a host ID = 0000:0000:0000:0000."
I believe this should be:
"An anycast address is essentially a unicast address assigned to multiple interfaces and/or devices.  One example of an anycast address is the Subnet-Router anycast address which has a host ID of 0 (0000:0000:0000:0000)."
Please reference RFC 4291 written by the legendary Steve Deering of none other than Cisco Systems.  :-)
--Jim
