My 1852i disconnect from WLC. And I start it display below. Sometimes need to input new username and password\ SSID, but I can't save it. And it automatically loop restart. Start the indicator is solid green. After a while blink green, and then blink red.
What's wrong with this AP?
U-Boot 2012.07 (btldr release 31) (Nov 15 2017 - 16:34:04)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM:  1 GiB
NAND (ONFI): Detected SPANSION S34MS02G2 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=7
PCI0 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3af POE or Others detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot:  0
Specified BOOT: part1
Read 1024 bytes from volume part1 to 45000000
Read 52495854 bytes from volume part1 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...       ***绿色固定的指示灯
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=500M-:64M@1280M console=ttyHSL1,9600n8 activepart=part1 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2200]
[01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:34.3194] ACPU PVS: 1
[01/01/1970 00:00:36.8886] buginf tty flushing thread started, ttyport=eed26690
[*01/01/1970 00:00:43.7865] buginf() enabled.
[*01/01/1970 00:00:43.7965] Made it into bootsh: Aug 17 2018 04:37:18
[*01/01/1970 00:00:43.7965] bootsh build T-6f8083fd2eea4fa63df1dba66ecd877dd988f69b-g6f8083fd-vipendya
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
            Cisco Systems, Inc.
            170 West Tasman Drive
            San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Sockets.
[  OK  ] Created slice -.slice.
[  OK  ] Created slice system.slice.
         Starting Cisco early mount...
         Starting Cisco platform file generation...
         Starting Cisco kexec...
[  OK  ] Reached target Slices.
         Starting Cisco system time setup...
[*01/01/1970 00:00:47.7253] Last reload time: Aug 21 21:25:59 2018
[*08/21/2018 21:25:59.0000] Setting system time Tue Aug 21 21:25:59 UTC 2018
         Starting Cisco seed generation...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Cisco early mount.
[  OK  ] Started Cisco platform file generation.
[  OK  ] Started Cisco kexec.
[  OK  ] Started Cisco system time setup.
[  OK  ] Started Cisco seed generation.
[  OK  ] Reached target Local File Systems.
         Starting Cisco S10 boot service...
         Starting Cisco klogd...
[  OK  ] Started Cisco klogd.
[  OK  ] Started Cisco S10 boot service.
         Starting Cisco syslog service...
         Starting Cisco nss service...
         Starting Cisco watchdog...
[  OK  ] Started Cisco syslog service.
[  OK  ] Started Cisco nss service.
[  OK  ] Started Cisco watchdog.
         Starting Cisco Kclick...
         Starting Cisco synclogd...
[*08/21/2018 21:26:00.0097] GCM-128 POST passed
[*08/21/2018 21:26:00.0097] GCM-256 POST passed
[*08/21/2018 21:26:00.4695] ===   5G radio domain is 51, COPY 5G BDF files from non_ETSI_BDF folder   ===
[*08/21/2018 21:26:00.6895] Active version: 8.8.100.0
[*08/21/2018 21:26:00.6895] Backup version: 8.3.102.0
[*08/21/2018 21:26:00.9194]
[*08/21/2018 21:26:00.9194]  led pattern module start
[*08/21/2018 21:26:00.9694] AP1852I
[*08/21/2018 21:26:01.0793] nss_driver - Turbo Support 1
[*08/21/2018 21:26:01.0793] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*08/21/2018 21:26:01.1093] NSS firmware booted
[*08/21/2018 21:26:01.1393] NSS firmware booted
[*08/21/2018 21:26:01.2393]
[*08/21/2018 21:26:01.2393] phy_value=0: org="0x1000" phy_reg="0x1800"
[*08/21/2018 21:26:01.5992] Current value of FACTORY_RESET=0
[*08/21/2018 21:26:01.6192] Last reload time: Aug 21 21:25:59 2018
[*08/21/2018 21:25:59.0699] device wired0 entered promiscuous mode
[*08/21/2018 21:25:59.1399] device wired1 entered promiscuous mode
[*08/21/2018 21:26:00.0697] stile module dp init successfully
[*08/21/2018 21:26:00.0697] NBAR Label:BLD_V166_THROTTLE_LATEST_20180116_031947 Module timestamp: Aug 17 2018 at 04:34:55 User: vipendya
[  OK  ] Started Cisco Kclick.
[  OK  ] Started Cisco synclogd.
         Starting Cisco nolan service...
         Starting Cisco printkd...
         Starting Cisco certificate create service...
[  OK  ] Started Cisco nolan service.
[  OK  ] Started Cisco printkd.
[  OK  ] Started Cisco nolan USB service.
[*08/21/2018 21:26:02.1890] Loading sha2...
[*08/21/2018 21:26:02.1890] Dumpping sha1...
[*08/21/2018 21:26:02.1990] miibus get eec95800!
         Starting Cisco nolan USB service...
[  OK  ] Started Cisco certificate create service.
         Starting Cisco certtime service...
         Starting Cisco brain service...
[  OK  ] Started Cisco certtime service.
[  OK  ] Started Cisco brain service.
[*08/21/2018 21:26:02.8588] Last reload reason : 0: unknown
[*08/21/2018 21:26:03.5486] Loading MIC cert and key
[*08/21/2018 21:26:03.5586] Dumpping sha2...
[*08/21/2018 21:26:04.8482] Loading MIC cert and key
[*08/2ÛmÚÍjzµ   i´ju¡¢ÉÑåÍѵJ¹¥Ñ¥±¥éÑ¥½¹¹jR´¥   ÂzzÂÒ²Ò²r²º²êRÔ´¥       ÂzzÂÒ²Ò²r²º²êÚeÅ+k«IJu¹½Éj½Õ±Éµ)jÚ¥ÂzzÂÒ²Ò²r²º²êz±}Ñ¡}½Ý¹±½}¥ÉµÝÉÒU½¹zQA"½Ý¹±½
        ¹*áÕÑJÍ:½½±ÉµõÂÁRÔ´¥      ÂzzÂbµ´5jzµ     i´ju¡¢ÉÑѡ͹jRü[  OK  ] Reached target Basic System.
         Starting Dropbear (SSH) server...
[*08/21/2018 21:26:07.1075] Generating key, this may take a while...
         Starting capwapd...
         Starting Cisco led service...
[  OK  ] Started Hostapd process.
         Starting Hostapd process...
[  OK  ] Started Cisco rtd service.
         Starting Cisco rtd service...
         Starting Clean Air daemon...
[*08/21/2018 21:26:07.7873] HTC Rx: insufficient length, got:4 expected =8
[*08/21/2018 21:26:07.7873] Startup Mode-0 set
[*08/21/2018 21:26:07.7873] HTC Service:0x0300 ep:1 TX flow control disabled
[*08/21/2018 21:26:07.7873] HTC Service:0x0100 ep:2 TX flow control disabled
[*08/21/2018 21:26:07.7873] Firmware_Build_Number:70
[*08/21/2018 21:26:07.7873] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339a79b2  vht_supp_mcs:0x0000ffaa
[*08/21/2018 21:26:07.7873]  RES CFG Support wmi_service_bitmap 9778
[*08/21/2018 21:26:07.7873]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*08/21/2018 21:26:07.7873] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*08/21/2018 21:26:07.8572] wmi_ready_event_rx:  WMI UNIFIED READY event
[*08/21/2018 21:26:07.8572] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*08/21/2018 21:26:07.8672] spectral_init_netlink 81 NULL SKB
[*08/21/2018 21:26:07.8672] ACS not enabled
[*08/21/2018 21:26:07.8672] ol_ath_thermal_mitigation_attach: --
[*08/21/2018 21:26:07.9572]  pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*08/21/2018 21:26:08.4670] Public key portion is:
[*08/21/2018 21:26:08.4670] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCXFTwO7pABIXLkPH0OaHPRthmhswmvaAeS+vvmiS6vw6YEmtAnd/HnyVXmyZgEXmaF1dUdJhlQNEJQOcXXV3D4zuQEygj9CY1cergD+F64Rk2knpeZgOUZ
nKS9sn3G0gNkCmPdr5fZWin0EHbEHqMzszteKlB7BHqEiUiQ47/rYLiQYeHC15ay8Gv4ZV5mGwGOYdMC3tI5YTSIACA8es5Ia0CGtqrf+K4YhIcbzrsu7zFpIV1xdIxr9ZJobgIm5w0sDU9JO+dZygoSGi/5E4xvP5lEXyEw2BQ2xOetGRAiSwKuUgjKA6VVx1nZpiCEwcKNrAOHG/l5S1ZqpWbio3zJ root@mD42C44E61C88
[*08/21/2018 21:26:08.4670] Fingerprint: md5 a2:99:96:03:94:e1:a1:89:45:90:35:07:4b:5e:7f:61
[*08/21/2018 21:26:08.7869] FWLOG: [60419] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*08/21/2018 21:26:08.7869] FWLOG: [60419] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*08/21/2018 21:26:08.7869] FWLOG: [60419] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*08/21/2018 21:26:08.7869] FWLOG: [60419] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*08/21/2018 21:26:09.7666] click-config/io-real.click:141: While configuring 'todev_wired0 :: ToDevice':
[*08/21/2018 21:26:09.7666]   warning: device 'wired0' is down
[*08/21/2018 21:26:09.7966] click-config/io-real.click:141: While configuring 'fromdev_wired0 :: FromDevice':
[*08/21/2018 21:26:09.7966]   warning: device 'wired0' is down
[*08/21/2018 21:26:10.0066]
[*08/21/2018 21:26:10.0066] Click sched monitor: schedulers = 1
[*08/21/2018 21:26:10.3465] click-config/io-real.click:141: While initializing 'tohost_wired0 :: ToHost':
[*08/21/2018 21:26:10.3465]   warning: device 'wired0' is down
         Starting Slow CGI daemon...
[*08/21/2018 21:26:10.8363] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[  OK  ] Started Fast CGI daemon.
         Starting Fast CGI daemon...
[  OK  ] Started Serial Getty on ttyS0.
         Starting Serial Getty on ttyS0...
[  OK  ] Reached target Login Prompts.
         Starting WCPD process...
[  OK  ] Started AP Trace daemon.
         Starting AP Trace daemon...
[  OK  ] Started Dropbear (SSH) server.
[  OK  ] Started Cisco led service.
[*08/21/2018 21:26:11.8560] pid 3601's current affinity mask: 3
[*08/21/2018 21:26:11.8560] pid 3601's new affinity mask: 1
[  OK  ] Started Slow CGI daemon.
[  OK  ] Started WCPD process.
[  OK  ] Started Clean Air daemon.
[  OK  ] Started capwapd.
         Starting dnsmasq watcher...
[*08/21/2018 21:26:12.0759] Password for 'Cisco' changed
[  OK  ] Reached target Multi-User System.
[*08/21/2018 21:26:12.9057] DOT11_TXP[0]:Domain configured: 1 class:E
[  OK  ] Started Lighttpd Daemon.
         Starting Lighttpd Daemon...
[*08/21/2018 21:26:13.0356] DOT11_TXP[1]:Domain configured: 51 class:H
         Starting dhcpv6 client watcher...
[*08/21/2018 21:26:13.7154] DOT11_DRV[0]: Init Radio0
[*08/21/2018 21:26:13.7454] DOT11_DRV[0]: Stop Radio0
[*08/21/2018 21:26:13.7454] DOT11_DRV[0]: set_channel Channel set to 6
[*08/21/2018 21:26:13.7554] DOT11_DRV[1]: Init Radio1
[*08/21/2018 21:26:13.7554] DOT11_DRV[1]: wifi1: Failed to get radio priv parameter (op 4234)
[*08/21/2018 21:26:13.7754] wifi1     no private ioctls.
[*08/21/2018 21:26:13.7954] wifi1     no private ioctls.
[*08/21/2018 21:26:13.8054] wifi1     no private ioctls.
[*08/21/2018 21:26:13.8154] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4283 arg 1)
[*08/21/2018 21:26:13.8154] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
[*08/21/2018 21:26:13.8154] DOT11_DRV[1]:  acfg_set_radio_param param 0x200d value 1 failed
[*08/21/2018 21:26:13.8354] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
[*08/21/2018 21:26:13.8354] DOT11_DRV[1]:  acfg_set_radio_param param 0x2017 value 1 failed
[*08/21/2018 21:26:13.8354] DOT11_DRV[1]: wifi1 acfg cmd 19 failed for wifi1 errno 19(No such device)
[*08/21/2018 21:26:13.8354] DOT11_DRV[1]: Radio 1 NF_Calibration request failed !
[*08/21/2018 21:26:13.8454] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4176 arg 1)
[*08/21/2018 21:26:13.8554] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4235 arg 1)
[*08/21/2018 21:26:13.8654] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4432 arg 2177)
[*08/21/2018 21:26:13.8753] DOT11_DRV[1]: wifi1 acfg cmd 16 failed for wifi1 errno 19(No such device)
[*08/21/2018 21:26:13.8753] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*08/21/2018 21:26:13.8753] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8F
[*08/21/2018 21:26:13.8953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*08/21/2018 21:26:13.8953] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8E
[*08/21/2018 21:26:13.9053] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*08/21/2018 21:26:13.9053] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8D
[*08/21/2018 21:26:13.9153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*08/21/2018 21:26:13.9153] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8C
[*08/21/2018 21:26:13.9153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*08/21/2018 21:26:13.9153] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8B
[*08/21/2018 21:26:13.9253] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*08/21/2018 21:26:13.9253] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:8A
[*08/21/2018 21:26:13.9353] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*08/21/2018 21:26:13.9353] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:89
[*08/21/2018 21:26:13.9353] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*08/21/2018 21:26:13.9353] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:88
[*08/21/2018 21:26:13.9453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*08/21/2018 21:26:13.9453] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:87
[*08/21/2018 21:26:13.9553] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*08/21/2018 21:26:13.9553] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:86
[*08/21/2018 21:26:13.9553] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*08/21/2018 21:26:13.9553] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:85
[*08/21/2018 21:26:13.9653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*08/21/2018 21:26:13.9653] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:84
[*08/21/2018 21:26:13.9753] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*08/21/2018 21:26:13.9753] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:83
[*08/21/2018 21:26:13.9753] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*08/21/2018 21:26:13.9753] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:82
[*08/21/2018 21:26:13.9853] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*08/21/2018 21:26:13.9853] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:81
[*08/21/2018 21:26:13.9953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*08/21/2018 21:26:13.9953] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr:  D4:2C:44:E6:D8:80
[*08/21/2018 21:26:13.9953] DOT11_DRV[1]: Stop Radio1
[*08/21/2018 21:26:13.9953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_stop_radio ioctl SIOCGIFFLAGS failed for wifi1 error -1
[*08/21/2018 21:26:13.9953] DOT11_DRV[1]: Failure to Stop radio during Base Driver Initialization
[*08/21/2018 21:26:14.0053] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*08/21/2018 21:26:14.0153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*08/21/2018 21:26:14.0153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*08/21/2018 21:26:14.0253] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*08/21/2018 21:26:14.0253] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*08/21/2018 21:26:14.0353] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*08/21/2018 21:26:14.0453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*08/21/2018 21:26:14.0453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*08/21/2018 21:26:14.0553] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*08/21/2018 21:26:14.0653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*08/21/2018 21:26:14.0653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*08/21/2018 21:26:14.0753] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*08/21/2018 21:26:14.0853] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*08/21/2018 21:26:14.0853] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*08/21/2018 21:26:14.0853] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*08/21/2018 21:26:14.0953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*08/21/2018 21:26:14.0953] DOT11_DRV[1]:  mon1 ioctl op=0x8bf2 len=4 failed: 19 (No such device)
[*08/21/2018 21:26:14.0953] DOT11_DRV[1]: set mode_str 11A to mon1 failed
[*08/21/2018 21:26:14.1053] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v0 error No such device
[*08/21/2018 21:26:14.1153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v1 error No such device
[*08/21/2018 21:26:14.1153] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v2 error No such device
[*08/21/2018 21:26:14.1253] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v3 error No such device
[*08/21/2018 21:26:14.1253] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v4 error No such device
[*08/21/2018 21:26:14.1353] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v5 error No such device
[*08/21/2018 21:26:14.1453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v6 error No such device
[*08/21/2018 21:26:14.1453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v7 error No such device
[*08/21/2018 21:26:14.1553] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v8 error No such device
[*08/21/2018 21:26:14.1653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v9 error No such device
[*08/21/2018 21:26:14.1653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v10 error No such device
[*08/21/2018 21:26:14.1753] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v11 error No such device
[*08/21/2018 21:26:14.1853] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v12 error No such device
[*08/21/2018 21:26:14.1953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v13 error No such device
[*08/21/2018 21:26:14.1953] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v14 error No such device
[*08/21/2018 21:26:14.2053] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver is_vap_present ioctl SIOCGIFFLAGS failed for apr1v15 error No such device
[*08/21/2018 21:26:14.2053] DOT11_DRV[1]: set_channel Channel set to 36
[*08/21/2018 21:26:14.2153] DOT11_DRV[1]: wifi1 acfg cmd 17 failed for wifi1 errno 19(No such device)
[*08/21/2018 21:26:14.2253] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4242 arg 0)
[*08/21/2018 21:26:14.2253] DOT11_DRV[1]: wifi1: Failed to set parameter (op 4241 arg 0)
[*08/21/2018 21:26:14.2353] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v0 error No such device
[*08/21/2018 21:26:14.2453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v1 error No such device
[*08/21/2018 21:26:14.2453] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v2 error No such device
[*08/21/2018 21:26:14.2553] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v3 error No such device
[*08/21/2018 21:26:14.2653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v4 error No such device
[*08/21/2018 21:26:14.2653] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v5 error No such device
[*08/21/2018 21:26:14.2752] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v6 error No such device
[*08/21/2018 21:26:14.2852] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v7 error No such device
[*08/21/2018 21:26:14.2852] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v8 error No such device
[*08/21/2018 21:26:14.2952] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v9 error No such device
[*08/21/2018 21:26:14.3052] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v10 error No such device
[*08/21/2018 21:26:14.3052] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v11 error No such device
[*08/21/2018 21:26:14.3152] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v12 error No such device
[*08/21/2018 21:26:14.3152] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v13 error No such device
[*08/21/2018 21:26:14.3252] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v14 error No such device
[*08/21/2018 21:26:14.3352] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_get_bssid ioctl SIOCGIFHWADDR failed for apr1v15 error No such device
[*08/21/2018 21:26:14.3452] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver get_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
[*08/21/2018 21:26:14.3452] populate_if_index_table: if_index -1 out of range for radio 1 vap 0 of 16
[*08/21/2018 21:26:14.3452] /usr/bin/wcpd: /data/BUILD/workspace/88_ME_CCO/corsica/router/base/../elts-meraki/elements/wcp/wcp_db.cc: 1865: void WcpDb::populate_if_index_table(): Asser
tion `if_index >= 0 && if_index < 64' failed.
[*08/21/2018 21:26:14.4152] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*08/21/2018 21:26:14.4352] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*08/21/2018 21:26:14.4352] ip6_port srcr6, ip6local fe80::d62c:44ff:fee6:1c88, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*08/21/2018 21:26:14.4352] USB Device Disconnected from the AP
[*08/21/2018 21:26:16.5346]
[*08/21/2018 21:26:16.5346] phy_value=0: org="0x1800" phy_reg="0x1000"
         Starting ntp watcher...
[  OK  ] Stopped DNSmasq.
[*08/21/2018 21:26:31.2400] systemd[1]: wcpd.service failed.
User Access Verification
Username:
Username: [*08/21/2018 21:27:04.6595]
[*08/21/2018 21:27:04.6595] !!!!! {watchdogd} Process wcpd gone for 60s
[*08/21/2018 21:27:15.8560] waiting for WCP to initialize
[*08/21/2018 21:27:15.8560] Waiting for sending msg to wcp/Radio0.set_radio_mode - 1
[*08/21/2018 21:27:16.8557] Waiting for sending msg to wcp/Radio0.set_radio_mode - 2
[*08/21/2018 21:27:17.8554] Waiting for sending msg to wcp/Radio0.set_radio_mode - 3
[*08/21/2018 21:27:18.8551] Waiting for sending msg to wcp/Radio0.set_radio_mode - 4
[*08/21/2018 21:27:19.8548] Waiting for sending msg to wcp/Radio0.set_radio_mode - 5
[*08/21/2018 21:27:20.8545] Waiting for sending msg to wcp/Radio0.set_radio_mode - 6
[*08/21/2018 21:27:21.8542] Waiting for sending msg to wcp/Radio0.set_radio_mode - 7
[*08/21/2018 21:27:22.8638] Waiting for sending msg to wcp/Radio0.set_radio_mode - 8
[*08/21/2018 21:27:23.8635] Waiting for sending msg to wcp/Radio0.set_radio_mode - 9
[*08/21/2018 21:27:24.8632] Waiting for sending msg to wcp/Radio0.set_radio_mode - 10
[*08/21/2018 21:27:25.8629] Waiting for sending msg to wcp/Radio0.set_radio_mode - 11
[*08/21/2018 21:27:26.8626] Waiting for sending msg to wcp/Radio0.set_radio_mode - 12
在这个过程绿色闪烁,然后红色闪烁
Leo Laohoo
RMA the AP.
NOTE:  The AP1800 have been having reported to have "hardware" issues in the forum.
Rich R
And in future please post questions like this in https://community.cisco.com/t5/wireless/bd-p/discussions-wireless as this is NOT a knowledge base post!
