Tom Randstrom
This document is designed to provide a reference guide for locating frequently requested information regarding pluggable optical transceivers;  better known to as GBICs, SFP/ SFP+s, XFPs, XENPAKs, X2s or other.  Although much of this information is found on Cisco’s website, sometimes it can be difficult to locate.
rspell
Tom,
Good document. It is good to see all of that information in one location. I don't think that you have this link listed, but you might consider adding it. http://www.cisco.com/en/US/prod/collateral/optical/ps5724/ps2006/brochure_c02-452560.html
That will show you all of the pluggable modules for the 15454, 15310, and 15327 that can be used with each card and which software loads.
Rex
Tom Randstrom
Rex,
Thank you for the information!  I don't remember ever seeing that ONS information before.  I have added it to my document and reposted.
Tom
scnoyes
Tom,
Here is another good link for GBIC, SFP and XFP on the Cisco ONS platforms.
https://www.cisco.com/en/US/docs/optical/spares/gbic/guides/ppms2.html#wp203291
This link includes installation guidelines along with descriptions, specifications and compatibility matrices.
-SteveN
Tom Randstrom
Steve,
Thank you for sending the link to the installation document for the ONS-Series Transceivers.  I have added it to my document (v4).
james.hicks
Tom,
Another document for consideration is one titled "Clarifying Optical Parameters, Power Budgets, and Fiber Plant Requirements for 10GBASE-E and 10GBASE-L".
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/prod_white_paper0900aecd8033fa80.pdf
The document illustrates the different methodology regarding selection of 10GB optics compared to 1GB optics.
Jay
Tom Randstrom
Jay,
Added you referenced link to the document.  Great read!
Thanx,
Tom
faisalfadhil
Thanks you very much. Very useful!
Hello, I'm having some trouble finding a data sheet for this item..XGS-PON Dual-Rate Transceiver
- Part Number: 100-05730
Can you point me in the right direction?
Thank-you
Frank
Rich R
