ekhabaro
Introduction
This article describes IPSec IKEv1 site-to-site VPN with pre-shared keys configuration in transport-vpn on vEdge between IOS device with VRF configured.
Components Used
vEdge router with 18.2 software or newer and Cisco IOS-XE router.
Configure
vEdge router configuration
vpn 0
 interface ge0/1
  ip address 192.168.103.7/24
  no shutdown
 interface ipsec1
  ip address 10.0.0.2/30
  tunnel-source-interface ge0/1
  tunnel-destination      192.168.103.130
  ike
   version      1
   mode         main
   rekey        14400
   cipher-suite aes128-cbc-sha1
   group        2
   authentication-type
    pre-shared-key
     pre-shared-secret $8$qzBthmnUSTMs54lxyHYZXVcnyCwENxJGcxRQT09X6SI=
     local-id          192.168.103.77
     remote-id         192.168.103.130
  ipsec
   rekey                   3600
   replay-window           512
   cipher-suite            aes256-cbc-sha1
   perfect-forward-secrecy group-2
  no shutdown
vpn 1
 ip ipsec-route 0.0.0.0/0 vpn 0 interface ipsec1
 Cisco IOS-XE configuration
crypto keyring KR vrf vedge2_vrf
  pre-shared-key address 0.0.0.0 0.0.0.0 key test
crypto isakmp policy 10
 encr aes
 authentication pre-share
 group 2
crypto isakmp profile IKE_PROFILE
   keyring KR
   self-identity address
   match identity address 0.0.0.0 vedge2_vrf
crypto ipsec transform-set TSET esp-aes 256 esp-sha-hmac
 mode tunnel
crypto ipsec profile IPSEC_PROFILE
 set transform-set TSET
 set pfs group2
 set isakmp-profile IKE_PROFILE
interface Tunnel1
 ip address 10.0.0.1 255.255.255.252
 description "*** IPSec tunnel ***"
 tunnel source 192.168.103.130
 tunnel mode ipsec ipv4
 tunnel destination 192.168.103.7
 tunnel vrf vedge2_vrf
 tunnel protection ipsec profile IPSEC_PROFILE isakmp-profile IKE_PROFILE
interface GigabitEthernet4
 description "*** vEdge2 ***"
 ip vrf forwarding vedge2_vrf
 ip address 192.168.103.130 255.255.255.0 secondary
Verify
1. Make sure remote address of peer is reachable:
csr1000v2#ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
2. Check if IPSec phase1 (IKE) is established on Cisco IOS-XE router, state should be "QM_IDLE":
csr1000v2#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
192.168.103.130 192.168.103.7   QM_IDLE           1004 ACTIVE
IPv6 Crypto ISAKMP SA
 3. Check if IPSec phase 2 is established on Cisco IOS-XE router and make sure that "pkts encaps" and "kts decaps" counters are increasing in both sites
csr1000v2#show crypto ipsec sa
interface: Tunnel1
    Crypto map tag: Tunnel1-head-0, local addr 192.168.103.130
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   current_peer 192.168.103.7 port 4500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 12, #pkts encrypt: 12, #pkts digest: 12
    #pkts decaps: 10, #pkts decrypt: 10, #pkts verify: 10
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 192.168.103.130, remote crypto endpt.: 192.168.103.7
     plaintext mtu 1422, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet4
     current outbound spi: 0xFFB55(1047381)
     PFS (Y/N): Y, DH group: group2
     inbound esp sas:
      spi: 0x2658A80C(643344396)
        transform: esp-256-aes esp-sha-hmac ,
        in use settings ={Tunnel UDP-Encaps, }
        conn id: 2023, flow_id: CSR:23, sibling_flags FFFFFFFF80004048, crypto map: Tunnel1-head-0
        sa timing: remaining key lifetime (k/sec): (4608000/1811)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2024, flow_id: CSR:24, sibling_flags FFFFFFFF80004048, crypto map: Tunnel1-head-0
        IV size: 16 bytes
     outbound ah sas:
     outbound pcp sas:
4. Check if IPSec phase 1 and 2 session are established on vEdge as well. State should be "IKE_UP_IPSEC_UP".
vedge4# show ipsec ike sessions
ipsec ike sessions 0 ipsec1
 version       1
 source-ip     192.168.103.7
 source-port   4500
 dest-ip       192.168.103.130
 dest-port     4500
 initiator-spi 8012038bc7cf1e09
 responder-spi 29db204a8784ff02
 dh-group      "2 (MODP-1024)"
 state         IKE_UP_IPSEC_UP
 uptime        0:01:55:30
vedge4# show ipsec ike outbound-connections SOURCE SOURCE DEST DEST CIPHER EXT IP PORT IP PORT SPI SUITE KEY HASH TUNNEL MTU SEQ -------------------------------------------------------------------------------------------------------------------------------------------------------- 192.168.103.7 4500 192.168.103.130 4500 643344396 aes256-cbc-sha1 ****ba9b 1418 no
5. Check if tx- and rx- counters are increasing as well in both directions and matching counters that were seen on Cisco IOS XE router.
vedge4# show tunnel statistics dest-ip 192.168.103.130
        TCP
TUNNEL                                    SOURCE  DEST  SYSTEM  LOCAL  REMOTE  TUNNEL                                          MSS
PROTOCOL  SOURCE IP      DEST IP          PORT    PORT  IP      COLOR  COLOR   MTU     tx-pkts  tx-octets  rx-pkts  rx-octets  ADJUST
ipsec     192.168.103.7  192.168.103.130  4500    4500  -       -      -       1418    10       1900       11       2038       1334
jcockburn
Hey All/ @ekhabaro ,
I am having issues with the above...
It looks very easy and seems straightforward but I just cannot get my lab up.
I keep getting the below:
*Jul 11 10:37:04.128: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 10.100.4.4 was not encrypted and it should've been.
101-0005-WR01#
*Jul 11 10:37:11.760: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at 10.100.4.4
That IP is the vEdge's VPN0 ip addr....
I obviously changed the IP addresses to match my lab, but other than that I use vEdge Cloud and some IOS router.
Will perhaps try another version....any help appreciated
Ciao
JC
brian.jones
I have the same issue.  Did you get any further in your issue?
