scottsassin
Level 4
Level 4
I have a 5508 WLC.  It came with Code 6.0.  I am trying to upgrade to 7.4.100.  No matter what I use, tftp or ftp, the download stops at 97MB.  The file is 116MB.  Is there something I am missing?  Do I need to delete something in flash to upgrade to this image?
TaylorW47
Visitor
you need to upgrade to 7.0 first, then step up to 7.4 - depending on the access points in your enviroment you may want to stay away from 7.4
bug CSCud97983
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud97983
scottsassin
Level 4
Level 4
Thanks.  I will try that.  I am using the 1042 access points, so I will stay with the 7.4.
Simerjeet Singh
Yes, 7.4 supports the following APs: Cisco 1040, 1130, 1140, 1240, 1250, 1260, 1600, 2600, 3500, 3500p, 3600, Cisco 600 Series OfficeExtend Access Points, AP801, and AP802
TaylorW47
Visitor
I have seen bug CSCud97983 be an issue with 1142, 2602, 3500, and 3600
