Jeffrey Keown
    The Virtual Controller Deployment Guide is the best reference for installing and initially configuring a vWLC:
    Cisco Virtual Wireless Controller Deployment Guide
    Cisco Virtual Wireless Controller Data Sheet
    Key Points
    The vWLC only supports AP’s in Flexconnect mode
    + All or some Wlans may still be centrally switched if preferred
    + If local mode (default) AP’s join the vWLC, they will appear to be functional, but will not beacon and service clients
    The following enhancement bug has been opened to proactively alert administrators of unsupported AP modes:
    CSCub46293 7500 and Virtual WLC: need to alert non support of non flexconnect ap's
    + AP’s may be automatically converted to flexconnect mode via the AP autoconvert cli command:
    (vWLC) >show ap autoconvert
    AP Autoconvert .................................. Disabled
    (vWLC) >config ap autoconvert flexconnect
    AP Autoconvert .................................. FlexConnect
    AP’s must be running 7.3 (15.2(2)JA) or later code to join a vWLC
    7.3.101.0 = 15.2(2)JA
    Refer to the following document for IOS to WLC code version cross reference:
    Table 1 Cisco WLC Software Releases, AP IOS Releases, and Supported Access Points
    + AP’s migrating from legacy controllers (eg 4400, 2100, WiSM, last code support 7.0) to vWLC’s must either first be moved to a 7.3 or later physical controller, or manually upgraded.
    License not active upon initial installation
    + A common point overlooked is that once a vWLC is initially installed, ‘0 Access Points Supported’ will be displayed on the vWLC’s Monitor page. A license (evaluation or permanent) must be activated before AP’s will be able to join.
    7.4 Configuration Guide – Managing Licenses
    Common Issues
    VM Port Mapping
    It is critical, during VM configuration, that the vWLC’s service port (VM Network Adapter
    1) and the vWLC’s Data Port (VM Network Adapter
    2) not be mapped to the same virtual switch. This is documented in the vWLC deployment guide, but often overlooked or misunderstood.
    Issues such as ap join stability, inconsistent access to external hosts (such as Radius or NMS servers) and degraded vWLC management interface response may be encountered.
    The following log message typically indicates this configuration state:
    *osapiReaper: Sep 10 16:57:24.575: #LOG-3-Q_IND: dhcp_proxy.c:3754 Received a DHCP packet sent by the controller itself possible network loop![...It occurred 5 times.!]
    Additional information
    CSCuj14843 vWLC: prevent service/data port confusion
    VMware configuration correction screenshots:
    Commonly encountered bugs
    CSCuf38985 AP can't join a second vWLC - trouble validating vWLC Self-Signed Cert
    CSCuf74326 valid vWLC license misinterpreted by vWLC : no AP count
    Additional Info
    vWLC license loading but not allowing ap's to join
    CSCul29834 AP not join vWLC due to SSC certificate validation failed
    CSCud56753 vMotion of vWLC causes extended loss of communication to management
    Hi!,
        What are the Guidelines if im using a Nexus 1000v switch insted of the VmWare vSwitches thats come by default??.
    mzouggagh
    Frequent Visitor
    Frequent Visitor
     It was very helpful for my Lab.
    I add:
    if you are using old AP (ex: 1041) with not supported firmware, use these commands to upgrade AP:
    # debug capwap console cli
    # archive download-sw /force-reload /overwrite tftp://w.x.y.z/c1140-rcvk9w8-tar.153-3.JD.tar
