DevNet Networking
Engage with peers and Cisco experts about networking developer tools and resources.
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Browse the Community
Crosswork Automation Hub
Welcome to the Automation Hub—a collaborative space designed for the automation community to foster ...
Controllers
Community space to connect, share knowledge, and seek guidance on network controllers and related to...
Network Devices
Explore, inquire, and collaborate on network devices.
Activity in DevNet Networking
Resolved! Terraform - iosxe provider - WLAN psk problems
Hello all,I am working on utilizing Terraform to manage our 9800 WLCs.So far everything with the ios-xe provider has worked well, though for most of our wireless settings, we have to use the restconf module from the provider to accomplish the intende...
hexabyte8 by Level 1
  • 167 Views
  • 3 replies
Reimagining Network Troubleshooting
Effective Network troubleshooting is one of the top, if not the number one, priorities for almost every network operations team. Having the tools and the skills to identify faster the root cause and impact of network issues has a direct connection wi...
jantich by Cisco Employee
  • 234 Views
  • 1 replies
pyATS HTML log viewer
pyATS has HTML log viewer which spins local web server when using the command "pyats logs view"Seems the test data comes from a .zip file which gets created after tests has been executed.How can that .zip file be converted to HTML for local viewing i...
l00pback by Level 1
  • 151 Views
  • 3 replies
Running multi-thread t-rex on AMD with Broadcom P2200G NIC card
Hello,I am failing to run multi-threaded t-rex.I have done following till now:1) I had upgraded firmware from following location:https://docs.broadcom.com/docs/BCM957608-P2200G_FW_235.1.160.0https://docs.broadcom.com/docs/NXE_Linux_niccli_235.1.151.0...
Siba- by Level 1
  • 230 Views
  • 2 replies
Resolved! Unable to Reserve DNACLab
Hi, Whenever I try to reserve a lab from the site "https://developer.cisco.com/catalyst-center/" for the options "Reservable Sandbox" or "Always-on Sandbox", it is throwing the below errors. 400 Bad Request Request Header Or Cookie Too Largenginx   ...
Anand G by Cisco Employee
  • 185 Views
  • 1 replies
Resolved! SDWAN API Authentication using AAA user.
Hi community Reading the documentation, I only see that SSO authentication is supported, but I'm wondering if AAA authentication is supported in vManage multitenant version 20.15.x.Because sometimes works and other failed.Response body can't parse JS...
Heri Diaz by Cisco Employee
  • 266 Views
  • 1 replies
pyATS constructor for common setup/cleanup routines
I would like to have multiple test suite .py files which will be run as a bundle by pyATS job.How can I have single defined common setup/cleanup routines which will run once whenever the pyATS job is executed instead of having the same common setup/c...
l00pback by Level 1
  • 214 Views
  • 1 replies
pyATS Unicon connection to Arista switch times out
Using EOS unicon plugin to connect to Arista switch.During device.connect(), password is sent and unicon logs: %UNICON-INFO: +++ connection to spawn: ssh .... Then it times out with TimeoutError error.One specific fact for this Arista switch is that ...
l00pback by Level 1
  • 514 Views
  • 10 replies
Pyinstaller not working with Genie and PyAts
Hello!   i have a perfectly working python script using Netmiko for connection to the devices and PyAts/Genie to do all the parsing, and it works beautifully, i have my organization devices inventory on an excel spreadsheet and with the script i can ...
Nano services in NSO 6.11
Hi, team I have a concern with nano service :I have a service with developed for NSO 5.83 initially, I have 5 step in my nano service at each step I have post-action that should be triggered when precondition are met. All work good in NSO 5.83 But wh...
Top Experts - Last 30 Days
