Backup and restore procedure for ND + NDFC
svenus
Asking for a detailed guide on how to set up a new ND + NDFC cluster, to restore a built cluster on purpose.
Issues that I have:
The customer is building a greenfield EVPN fabric, with new UCS and new storage. However, the new VMware infrastructure relies on the new N9K EVPN fabric - this is going to be a chicken-and-egg problem:
 - The greenfield fabric won't be ready until ND/NDFC is deployed
 - The ND/NDFC cluster won't be able to be built without deploying the compute and storage
 - But the compute and storage rely on the new fabric
Now one of the way to resolve that is I'm going to build the ND/NDFC cluster in their existing VMware, then have the OOB cross connect to the new fabric and start to build the new fabric there. Then once everything is ready, I migrate the NDFC cluster over to the new VMware environment.
Question is, is there a an official guide on how to properly do a backup and restore of the ND/NDFC cluster?
Do I first deploy the cluster again with the same IP addresses and then once I have got connectivity then do the restore?  This will need to turn off the existing cluster since the IP addresses will be reused.
Any guidance and insight, please?
ADP89
Svenus,
As a best practice you should not provide ND/NDFC access from the fabrics controlled by the application.
Having said this, if you do not have any other options on where to run those VMs then yes, a backup/restore will work.
No need to maintain the IPs, worst case scenario NDFC will push a new SNMP trap host configuration to all the switches..
Here you can find the guide:
https://www.cisco.com/c/dam/en/us/td/docs/dcn/ndfc/1213/articles/ndfc-backup-restore-lan/backing-up-and-restoring-lan-operational-mode-setups.pdf
HTH,
ADP
