07-01-2023 04:48 AM
Hello all, we have made the mistake of running factory-reset on of our Cisco Nexus 9336C-FX2 switches.
After the reset, the switch is now stuck in loader prompt. We tried setting IP and getway for tftp boot but are unable to ping the IP.
Could anyone guide us with this.
Case has been raised with Cisco Support but since this is a new switch and not in production, priority is P3.
07-01-2023 04:51 AM
Do
> dir
Then select image yoù want to boot
Do
> boot image
Wait
And you can enter from there
07-01-2023 07:16 AM
Hello @nastor5,
Do Dir: then check if an image exist, if yes boot on that bin file if not try to put the image on an usb stick and boot from there.
