DATA interfaces on Nexus Dashboard
suneq
I'm going to deploy some Nexus Dashboard physical appliances to manage our VXLAN fabric (a preprod one with only 1 Spine and 2 Leaf)
I have a few questions regarding the Data interfaces of ND:
  • how should I physically connect them to the Fabric? I have not found yet the documentation but it seems that I can connect the 1st port of ND to LEAF 1, 2nd port to LEAF2?
  • Is there any specific configuration on LEAF ports?
  • How the default gateway of Data Network should be configured (for example if I configure 10.0.0.1/24 on ND1, 10.0.0.2/24 on ND2, 10.0.0.3/24 on ND3 and want to use the default gateway 10.0.0.254 - is this address should be configured on the LEAF?
Thanks a lot for your help.
Niamh69
@suneq wrote: AvalonAccess Login
Thanks for the information, I will try to figure it out for more.
