10-10-2022 04:09 AM
I have 4 service node (Nexus Dashboard) and have multi-site scenario. Can I use it all 4 in a single site ? Is there any challenges in doing so?
And from the above scenario when I implement all nexus dashboard in a single site. How much bandwidth is required for nexus dashboard insight traffic at the WAN link when devices (2*Spine and 20*Leaf) sends data through WAN to other site nexus dashboard? So that I can plan the bandwidth on the WAN link accordingly. Need help urgently
Thanks in Advance.
@Gary25Bell Do you know someone .
10-19-2022 02:29 AM
@Jainul Hi Jainul, you can setup 3 maters nodes and 1 worker node as a cluster in a single site.
Each Nexus Dashboard cluster typically consists of 1 or 3 master nodes. For 3-node clusters, you can also provision a number of worker nodes to enable horizontal scaling and standby nodes for easy cluster recovery in case of a master node failure. For maximum number of worker and standby nodes supported in this release, see the "Verified Scalability Limits" sections of the Cisco Nexus Dashboard Release Notes.
For a details deployment model and bandwidth, you must always use the lowest RTT requirement when deploying the Nexus Dashboard cluster and services. For example, if you plan to co-host the Insights and Orchestrator services, site connectivity RTT must not exceed 50ms.
Service |
Connectivity |
Maximum RTT |
Nexus Dashboard cluster |
Between nodes |
150 ms |
Nexus Dashboard Orchestrator |
Between nodes |
150 ms |
To sites |
For APIC sites: 500 ms For NDFC sites: 150 ms |
Nexus Dashboard Insights |
Between nodes |
50 ms |
To sites |
50 ms |
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco Nexus Dashboard through our live Ask the Experts (ATXs) session. Check out this ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
