DNFC doesn't discover all interfaces a switch in an external fabric
mushtaq-elhajaj
I am running Nexus Dashboard Fabric Controller (NDFC) Version 12.1.3b in a lab environment with switches in EVE-NG. My multisite setup is functioning correctly, with N9K switches deployed across all sites without issues.
I recently created an external fabric and added a Catalyst 9K switch to it. However, NDFC is only discovering a single interface—the one connected to the management network. The other interfaces are not being discovered.
Does anyone know why this might be happening? I need to discover the other interfaces so I can configure them for eBGP peering. Any insights or suggestions would be greatly appreciated.
Thank you in advance for your help!
Cheers
Mushtaq
M02@rt37
Hello @mushtaq-elhajaj
Please refer here https://www.cisco.com/c/en/us/td/docs/dcn/ndfc/1201/configuration/fabric-controller/cisco-ndfc-fabric-controller-configuration-guide-1201/fabrics.html#task_sbz_qzk_1rb
--Adding Cisco Catalyst 9000 Series Switches to IOS-XE Easy Fabrics
Best regards
Hi M02@rt37,
The document you shared is great. But it didn't help. I am still seeing one
interface even after the SNMP configuration.
mushtaq-elhajaj
Hi M02@rt37 , Thank you for sharing this document. I have the SNMP configuration but still see one interface only basically I only see the interface that is connected to the cloud (mgmt network) but not the other interfaces. I hope someone experienced that issue to help please!!
