Ndfc proxy and external backup
ilanmelkamo052621
Frequent Visitor
Frequent Visitor
We are deploying Nexus Dashboard Fabric Controller (NDFC) in a secured on-prem environment.
All outbound internet access must go through an HTTP/HTTPS proxy.
We would like to clarify:
1. Does NDFC support downloading NX-OS images, application updates, and service packages through an HTTP/HTTPS proxy?
2. Which FQDNs/URLs and TCP ports must be allowed through the proxy?
In addition, we would like to understand the backup capabilities:
3. Is it possible for an external backup system to initiate a connection to NDFC and pull backups?
4. If not, is backup supported only as a push operation from NDFC to an external repository?
5. Which protocols and ports are supported for external backup integration?
Thank you.
balaji.bandi
As long as Proxy allows you to download, you should be able download software; most of the time, it is http/https ports.
Not sure about remote logging and taking a backup
But schedule backup in possible different ways, NAS or SFTP/SCP (port 22)
You can find more information depending on the version :
https://www.cisco.com/c/en/us/td/docs/dcn/nd/3x/articles-321/nexus-dashboard-back-up-and-restore-unified-321.html
BB
Thanks.
Just to confirm – besides opening TCP 443/80, are there specific Cisco FQDNs that must be explicitly allowed through the proxy for NDFC software downloads?
*.cisco.com
BB
