NDFC - Switch not accessible
Wrecktangle
Nexus Dashboard v3.2.1i
Fabric Controller v12.2.2.241
Under the default admin login, I'm able to access Fabric Controller --> Manage --> Zoning and perform zoning without issue. When logged in via TACACS (ISE) with a network-admin role assigned, I get "Switch not accessible" and I'm not able to even view the zoning, let alone perform any zoning. Any idea as to what could cause this?
I have the following assigned in my TACACS/ISE configuration:
MDS Error:
balaji.bandi
is this working before  upgrade to 3.2.1 or its installed 3.2.1 ?
is the devices also configured TACACS ?
are you able to SSH to device using AAA ?
BB
Fresh install of 3.2.1 (ova build actually) along with fresh NDFC install.  Yes, the devices are configured for TACACS and SSH using TACACS/AAA works.
What's puzzling is that the default ND admin ID works. My ID is only limited--rather I only receive the above error--in the zoning portion. My ID can access everything else.
What logs do you see on the ISE side when you access that information?
BB
