ā03-25-2024 07:05 PM
Hello experts,
I have currently an OSPF process running on a Nexus switch. I have a requirement to bring another OSPF neighborship with the same neighbor but under a VRF.
The question is can I use the existing OSPF process and do something like this
router ospf 100
router-id 4.4.4.4
area 7.7.7.7
vrf TEST
router-id 5.5.5.5
area 7.8.8.8
Solved! Go to Solution.
ā03-26-2024 12:25 AM
I add Router-id for ospf in global and add new router-id for ospf in vrf MHM
and you can see it accept by NSK SW
MHM
ā03-25-2024 09:30 PM
I will check this in my lab tonight, but I think OSPF use same router-id for both global and per-vrf, but let me check
MHM
MHM
ā03-26-2024 10:35 AM
Thanks a lot appreciate!!
