So I'm running ND 2.3 (2d) NDFC as a Fabric Controller 12.1.2e with Performance Monitoring, PTP Monitoring and Ip Fabric for Media enabled. I am trying to get the flow stats for NBM and the PTP Monitoring to work. I got it to work way back in DCNM, but for some reason the telemetry Sync in the Fabric View will always show Telemetry Sync Status is "ERROR" with no further information.
Fabric Controller-LAN-> Fabric 'IPMF', then top right corner to go into the fabric. Then 'Flows', It always displays the telemetry sync status as Error.
Same if I go into an individual Switch. PTP tab says: Ressource not found, Telemetry Sync Status: n/a, same for ptp corrections.
Also..is PTP monitoring now part of Insights??? I can't seem to find it in the fabric view. Even though it is enabled under feature management.
Thanks!
