Accessing a a yang list in Python code
Fantolino
Hi! I’m trying to access in python to the elements of a yang list. The yang model is:
      list Prenotazione {
        key "TempoAtt";
        unique "TempoDis";
        leaf TempoAtt {
          type string
And the code I’m trying to use is something
       FirstElementKey = service.Prenotazione.????
In order to access the leaf inside le list element with code such as:
    MyData = service.Prenotazione[FirstElementKey].LeafName
How can I do? Is it corect to assume the lis is ordered according to the key?
jfloresr
Hi, in service create code, the service object is an instance of the particular service being instantiated at that moment.
For example (using your yang model):
service.TempoAtt
If you want to access data from other service instances use the root object like so:
root.services.Prenotazione[FirstElementKey]
BTW root.services.Prenotazione returns an iterator so you can just walk it without needing to know the keys.
For what I have seen yes, the service is ordered by the key.
jfloresr
service.TempoAtt
