NSO Developer Hub Discussions
Hi all,We have multiple nso environments. In only one of them some users have a problem with the command load merge terminal.The commands look as followsncsadminuser@INT2# configEntering configuration mode terminalncsadminuser@INT2(config)# load merg...
Hi all, May anyone here know whether developer days will be organized in near future, or it is not decided yet or it is ended.Sorry if this information has already been made available and i missed it.Thanks and regards.
ekasnak by • Community Member
  • 367 Views
  • 2 replies
  • 1 Helpful votes
Hi, all:I am using NSO-6.6 and I encouter NSO-6.6 logs the following warning:<WARN> 22-Jan-2026::14:24:55.214 MmapCSMountPoint Did-6-Worker-3: - failed to get children, path 107781231, mountId smf5.1-nc-1.0:smf5.1-nc-1.0 from MountPointDbThis does no...
sm000x by • Level 5
  • 1017 Views
  • 3 replies
NSO behavior running a python NSO action seems to be to create one python ExecuteAction instance that handles all callbacks from NSO. For example, this single instance is what handles two users invoking the action.Is there a way to get one python ins...
MikeG3 by • Community Member
  • 1126 Views
  • 2 replies
