alarm handling
spudukko
Suppose for a particular device if i wanted to ignore specific alarms  for example like "Revision error"  based on alarm_text. I understand one can use the option notify_cli disable but that would disable based on severity like minor , major.
I understand administrator alarm handling where an admin can request state changes to alarams by ack, closed but if i wanted to customize the alarm manager and ignore certain alarms what is the procedure.
Dan.Sullivan
You should consult the NSO documentation on this topic and  see if that helps.
-Dan
Hi Dan,
Thanks for replying back.I am unable to find any specific commands to ignore specific text for example like "Revision error"  based on alarm_text.  If you can point me in right direction, it would be great.Appreciate the help.
Subramanian
Hi Subramanian,
As you've discovered you can't purge alarms based on the text, I believe you'd have to implement such a feature yourself.
-Dan
