'An NSO Lab' broken
Tom Deckers
Hi team,
Looks like the NSO lab (https://developer.cisco.com/docs/nso/#!an-nso-lab) is broken:
Any suggestions?
Thanks!
Tom.
Thanks for bringing this to my attention. I simply added Yftach's suggestion to the steps to take for now, we might have to rework the lab eventually though.
yfherzog
I'm not familiar with this lab and I don't know who maintains it, but if you're just interested in making it work, then the issue seems to be that the NSO environment variables were not loaded.
Usually you execute 'source path/to/ncsrc', but here source is not installed, so you can use '.' instead.
NSO seems to be installed under /app/nso/ncsrc.
So you can do:
# which ncs
# . /app/nso/ncsrc
# which ncs
/app/nso/bin/ncs
This seems to be enough for the first lab.
Not sure about the rest though... :)
