08-17-2017 06:10 AM - edited 03-01-2019 03:57 AM
I'm having no success in finding examples of how to write a tfcp:policy rule syntax in the ncs_cli or the NSO web interface?
Would someone point me in the right direction or provide some simple examples?
Solved! Go to Solution.
08-17-2017 12:03 PM
Interesting...
So... i went and tried this (yours...) it fails...
Went to look for more details... (tail -f *.* in logs ) and all that... saw some errors..
17-Aug-2017::10:58:46.491 Evaluating XPath for policy: foo:
/ios:interface[type = 'GigabitEthernet']
keypath not found: "/ios:interface"
Decided (after trying a few things) to look for more guidance...
Noticed that there is a section in the NSO Users Guide (e.g. nso_user_guide-4.4.2.pdf)
on page 85.... This guide provides an example that differs somewhat from the one in the YANG file
Example 19. Policies
ncs(config)# policy rule gb-one-zero
ncs(config-rule-gb-one-zero)# foreach /ncs:devices/device[starts-with(name,'ce')]/config
ncs(config-rule-gb-one-zero)# expr ios:interface/ios:GigabitEthernet[ios:name='0/1']
ncs(config-rule-gb-one-zero)# warning-message "{../name} should have 0/1 interface"
ncs(config-rule-gb-one-zero)# commit
zork(config-rule-gb-one-zero)# top
I "tested" it... modified slightly to have "error-message" instead of "warning-message"
admin@ncs% switch cli
admin@ncs(config)# policy rule foo
Value for 'expr' (<string>):
admin@ncs(config-rule-foo)# foreach /ncs:devices/device[starts-with(name,'c')]/config
admin@ncs(config-rule-foo)# expr ios:interface/ios:GigabitEthernet[ios:name='0/1']
admin@ncs(config-rule-foo)# error-message "{../name} should have 0/1 interface"
admin@ncs(config-rule-foo)# commit
Commit complete.
trying this out...
admin@ncs(config)# no devices device c0 config ios:interface GigabitEthernet 0/1
admin@ncs(config)# validate
Failed: c0 should have 0/1 interface
admin@ncs(config)# commit
Aborted: c0 should have 0/1 interface
admin@ncs(config)#
that seems to work...
(have not tried to re-format the MTU example you had...)
cheers
gregg
08-17-2017 08:56 AM
Hi Eric
never tried this - but...
a) found the YANG file... often times good/interesting info is directly incorporated here...
E.g. (for me)
./nso-4.4.2/src/ncs/configuration_policy/tailf-configuration-policy.yang
which includes:
description
"This module defines configuration policies. A configuration policy
enforces custom validation rules on the configuration data.
These rules assert that the user-defined conditions are always
true in committed data. If a configuration change is done such
that a policy rule would evaluate to false, the configuration
change is rejected by the system.";
and:
description
"An XPath 1.0 expression that is evaluated when the configuration
is validated, either when a validate operation is performed,
or at commit time.
The result of the expression is converted to a boolean using
the standard XPath rules. If the result is 'false', validation
fails with an error or a warning, as specified in the 'action'
choice.
For example, in order to verify that no ethernet interface has
a MTU other than 1500, the following expression can be given:
foreach '/interfaces/interface[type = ethernet]'
expr 'mtu != 1500'
error 'Ethernet interface {name} must have MTU 1500'
So i tried that... (had to use " and not ')
admin@ncs% set policy rule foo foreach "/interfaces/interface[type = ethernet]" expr "mtu != 1500" error-message "Ethernet interface {name} must have MTU 1500"
[ok][2017-08-17 08:48:20]
[edit]
admin@ncs%
admin@ncs% commit
Commit complete.
[ok][2017-08-17 08:48:35]
[edit]
admin@ncs%
admin@ncs% show policy rule
rule foo {
foreach "/interfaces/interface[type = ethernet]";
expr "mtu != 1500";
error-message "Ethernet interface {name} must have MTU 1500";
[ok][2017-08-17 08:48:50]
[edit]
admin@ncs%
admin@ncs% delete policy rule foo
[ok][2017-08-17 08:49:52]
[edit]
admin@ncs% commit
Commit complete.
[ok][2017-08-17 08:49:53]
[edit]
admin@ncs%
perhaps this helps...
Cheers
gregg
08-17-2017 09:23 AM
This can be very useful at times.
And, you forgot single quotes around 'ethernet' (or whatever value you want to compare against, e.g. 'ethernetCsmacd') in the foreach expression.
08-17-2017 09:27 AM
Thanks Jan
good comment - i just pulled the example from the YANG file description field... - to help the original poster.
didn't actually try it fully -- but it is an interesting !
thanks
gregg
08-17-2017 10:43 AM
Thanks for the quick replies ![]()
I've been trying to test (fail) the policy by the following:
foreach "/ios:interface[type = GigabitEthernet]";
expr "mtu != 1500";
set devices device s00-rtr config ios:interface GigabitEthernet 0/0/3 mtu 4400
... but it allows it to configure and commit.
Any ideas?
08-17-2017 12:03 PM
Interesting...
Commit complete.
trying this out...
admin@ncs(config)#
cheers
gregg
08-17-2017 12:24 PM
SUPER APPRECIATE!!!!
Your latest gets me through the front door. ![]()
08-17-2017 12:32 PM
awesome!
(I learned new things today too! thanks for asking the question)
08-18-2017 03:43 AM
hi Eric,
Here some of the examples I use for IOS/XR/Juniper in my demos:
1) I force the loopback 0 to never be in shutdown mode.
2) I force the ISIS metric to be always greater than 99.
I hope this helps!
Roque
tfcp:policy {
tfcp:rule loopback-up-ios {
tfcp:foreach /devices/device;
tfcp:expr not(config/ios:interface/ios:Loopback[ios:name='0']/ios:shutdown);
tfcp:error-message "Loopback 0 is cannot be shutdown";
tfcp:rule loopback-up-juniper {
tfcp:foreach /devices/device/config/junos:configuration/interfaces/interface[name='lo0'];
tfcp:expr not(disable);
tfcp:error-message "Loopback 0 cannot be shutdown";
tfcp:rule loopback-up-ios-xr {
tfcp:foreach /devices/device/config/cisco-ios-xr:interface/Loopback[id='0'];
tfcp:expr not(shutdown);
tfcp:rule isis-metric-juniper {
tfcp:foreach /devices/device/config/junos:configuration/protocols/isis/interface/level/metric;
tfcp:expr .>99;
tfcp:error-message "ISIS metric MUST be larger than 100";
tfcp:rule isis-metric-iosxr {
tfcp:foreach /devices/device/config/cisco-ios-xr:router/isis/tag/interface/address-family/ipv4/unicast/metric;
tfcp:expr .>99;
tfcp:rule isis-metric-ios {
tfcp:foreach /devices/device/config/ios:interface/GigabitEthernet/isis/metric;
tfcp:expr .>99;
08-18-2017 06:15 AM
Thanks again, you've been a HUGE help!!!
