BMC Patrol monitoring for NSO
ron.whitt
We're having BMC Patrol setup on an NSO server to monitor the application performance.  We're being asked for certain application parameters, which are of interest to Patrol.  I have the ask listed below.  Has anyone set up BMC Patrol, if so, what were the parms you used to feed Patrol?
  • Web / Application Service (mandory non-system level filesystem mount points):
         Typical Filesystem Mount Points for each instance are
      • WebSphere Filesystem mount point
      • Application Filesystem mount point
      • Log Filesystem mount point
      • Example: /appvol, /appvol/GWS/HQS
    • Process (application processes for each instance can be monitored)
      • Example
        • Process String: /opt/IBMIHS70/bin/httpd.*LWSGWSABM1HK
        • Process String: /opt/WebSphere70/AppServer/java/bin/java.*LASGWSABM1HK
  • Database Service:
    • Database filesystem mount points for each instance can be monitored.
    • Example:
      • ora_pmon_abc
    • File System
    • Database processes of each DB instance can be monitored.
  • Log (application log messages):
Jan Lindblad
I am not aware of any BMC Patrol usage with NSO, but then again, I would not be the person to know about any such cases.
There is no websphere in NSO. The directories are specified at installation time, but an NSO System Installation has these default directories:
InstallDir - /opt/ncs
ConfigDir  - /etc/ncs
RunDir     - /var/opt/ncs
LogDir     - /var/log/ncs
        • Example
The NSO processes have the following strings as part of their command line:
- "lib/ncs/erts/bin/ncs.smp" (unless running the single core version, which doesn't have .smp at the end)
- "inet_gethost"
- "lib/ncs/lib/core/ncs/priv/snmp-config-transform"
- "com.tailf.ncs.NcsJVMLauncher"
- "lib/ncs/lib/core/sls/priv/webapp-runner.jar"
There may be additional transient processes depending on the setup, e.g. ncs_cli processes as operators log onto the shell.
Database Service:
  • Example:
    • ora_pmon_abc
    • File System
The CDB database is built-in to NSO (for performance), so there is no separate process. There is a database directory is inside the NSO RunDir, often called ncs-cdb. Database related log messages are in the same log files as the rest of NSO.
Hope this helps.
Jan Lindblad
        • Example
- "inet_gethost"
Database Service:
  • Example:
    • ora_pmon_abc
    • File System
Hope this helps.
Thanks Jan! the number of beers I owe you keeps growing
For others viewing this post.  This was a request on a commercial deployment.  The deployment team said the info Jan gave was exactly what they needed.
