Boolean operation for if-ned-id xpath function in templates
rogaglia
I want to apply a boolean operation in the if-ned-id function, in particular an OR for two types of NEDs.
Is this supported?
Tried without success:
<?if-ned-id zte-nc-1-nc-1.0:zte-nc-1-nc-1.0 or if-ned-id hw-nc-1.0:hw-nc-1.0?>
<?(if-ned-id zte-nc-1-nc-1.0:zte-nc-1-nc-1.0) or (if-ned-id hw-nc-1.0:hw-nc-1.0)?>
Roque
ramkraja
You just have to separate the ned-id's with a space or a newline. Don't use "if-ned-id" twice in the instruction. So:
<?if-ned-id zte-nc-1-nc-1.0:zte-nc-1-nc-1.0 hw-nc-1.0:hw-nc-1.0?>
No other 'boolean operation' makes sense here. (you can even have more than two ned-id's, and it will pass if any one of them is loaded).
/Ram
ramkraja
/Ram
Thanks!
Hi Ram,
Maybe an additional question, do you know if I can run XPATH string functions in "if-ned-id" call? The user story would be "every cisco-ios-* NED or every huawei-vrp* NED".
Thanks!
Roque
No. Currently, the implementation only splits the contents based on whitespace or newlines, and checks if any of the ned-id's are loaded. There is no support for wildcards or xpath string functions as of now.
/Ram
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
