Bug tracking in NED
Ben Kelly
I'm trying to find out which version of the ASA NED has the fix for CSCvc44620. Is there somewhere I can find out this information?
fzeisig
This question was answer in a separate mailthread last fall. Publishing the answer (updated a bit to reflect present situation and not what was in fall last year) for larger knowledge sharing.
The ticket-references in CHANGES (bundled with the NED) referees to either a NSO BU Jira-ticket and/or a NSO BU RT-ticket. Unless there is no reference to the engineering ticket (Jira/RT) in CDETS or in CSOne then (for the moment) you must query the NSO BU to get the information you are asking for. There is migration-project of ticket-systems within the NSO BU, which should result in CHANGES entries referring to the customer (CDETS or CSOne) ticket as well. Ill bring it up with the process owner.
Below is an example of the reference to Jira (ASA-71) and RT.
  - Additions to the YANG model:
     object network * / nat * service tcp|udp
    (ASA-71 / RT27662)
fzeisig
    (ASA-71 / RT27662)
